Miss fires and shuts off
Old Sep 10, 2016 | 06:24 AM
Vrodjoe's Avatar
Vrodjoe
6th Gear
Default Miss fires and shuts off
Please Help I have a 2001 FLTRISE2. It miss fires a couple of times and shuts down. When it misfires I can see a yellow "flame" thru the throttle body. Same when hot or cold. I checked my alternator and regulator. They check out good. I put in a new cam and crank sensor. I also checked the wiring for a grounding problem . Its good. It has 90000 mile on it. complete go over at 50000 . Any ideas? I'm missing something. I been a member for a while . This is my first time in the forum.
Thanks
Joe
Old Sep 10, 2016 | 07:45 AM
lyork's Avatar
lyork
Sounds like an ignition module problem. Is it the stock unit or aftermarket?
Old Sep 10, 2016 | 10:54 AM
Vrodjoe's Avatar
Vrodjoe
6th Gear
Stock from factory.
Thanks for answering.
Old Sep 10, 2016 | 11:08 AM
Quiet Thunder's Avatar
Quiet Thunder
Was it running properly before you did the maintenance on it? I've found out, don't ask me how, if it don't run right, go back and undo what you do do... Then do over. I did some stuff to mine, and had to re do it. Worked the second time. A missed or not making a good power connection? Pushed in pin on a connector? Broken wire on a plug connector? Arcing?
Old Sep 11, 2016 | 05:02 AM
Vrodjoe's Avatar
Vrodjoe
6th Gear
Yes I was out on a ride when it started to cough and then just stop running. .Took me a second to restart. its been acting like this ever since. You are right by going over things you did. I just don't know if it is electrical or a gas issue. I don't have the money to take it to Harley (They really suck here in Charleston SC ) Is there any way to check the ignition module other than going to a dealer? I appreciate any and all help.
Joe
Old Sep 11, 2016 | 10:58 AM
svarnster's Avatar
svarnster
hey joe I am just south of you, did you get fuel close to the time this happened could have gotten some water - bad gas
Old Sep 11, 2016 | 05:20 PM
ORradtech's Avatar
ORradtech
Fire out of the Throttle body sounss more like backfiring than missing out. Two different problems really.
I think of backfiring as a timing issue. You said you replaced the cams and cam sensor, how recently?
Do you have any trouble codes?
Old Sep 11, 2016 | 05:27 PM
Boomer1143's Avatar
Boomer1143
Back firing through the intake is usually an indication of an extremely lean mixture. I would verify you have correct fuel pressure and flow.
Old Sep 11, 2016 | 07:36 PM
checkers's Avatar
checkers
Clean and tighten battery cables, also test for vacuum leak around TB/carbs
Old Sep 12, 2016 | 10:40 AM
nytryder's Avatar
nytryder
Check compression. Could be a worn or burnt valve.
