Replace belt or...
Old Sep 20, 2016 | 11:42 PM
Neil's Avatar
Neil
Default Replace belt or...
So the stator crapped out on the bike (2nd in 10 years). Bike has just over 70,000 on it. Since I had to pull the outer primary and the comp/chain/clutch out I thought I would replace the inner primary bearing with a sealed Baker High Torque. Trying to decide if I should take thing a step further since the primary will be off and replace the drive belt. No bad wear, no rock holes that I have seen, but, I did have something get caught between the front sprocket and primary that wore a small, shallow groove in the outer part of the belt last year. Any tips on replacing drive belt? Any methods to not have to completely pull rear swing arm off? 02 Ultra.
Neil
RDMC
Old Sep 21, 2016 | 03:40 AM
Goose_NC's Avatar
Goose_NC
You do not have to remove the swing arm to replace the belt. But you do have to loosen the mounts and slide it over. My last ElectraGlide the belt lasted me 98,000 miles. With the damage you stated, I'd replace it because it is not something I'd want to replace roadside.
Old Sep 21, 2016 | 05:11 AM
grbrown's Avatar
grbrown
I suggest you also inspect both pulleys for wear and damage. As with a chain, there's no point spending on a new belt if either or both pulleys are worn/damaged.
Old Sep 21, 2016 | 07:20 AM
lkr0's Avatar
lkr0
totally agree -- I had a bad pulley on my 09 RG belt snapped twice -- the second time the tech inspected the pulley -- some spines had become sharp
Old Sep 21, 2016 | 09:31 AM
6 gun's Avatar
6 gun
Replace the belt and check the pulleys.
Old Oct 8, 2019 | 07:30 PM
RBlackhawk45's Avatar
RBlackhawk45
6th Gear
Got a new pully with the new S&S motor just over a year ago. As for the 5 speed I pulled it and bought a Jims 6 speed. Right side is buttoned up and working on the drive side.
RBlackhawk45
6th Gear
I bought the recommended Torco 80W90 gear oil. Changing the motor and primary oil (of course). Any recommendations? VTwin 20-50?
Old Oct 8, 2019 | 07:37 PM
Hoginedgewood's Avatar
Hoginedgewood
I'm thinking the front pulley was steel and the rear was aluminum on my o6, front was fine, back had sharpened.
Old Oct 8, 2019 | 07:45 PM
RBlackhawk45
6th Gear
Outside of the front and rear pulleys was fine. Front pulley nut bolts sheered, the nut loosened and the pulley went wonky then stripped smooth as glass by the main gear.
Old Oct 9, 2019 | 05:34 AM
86glider's Avatar
86glider
Front are steel, rear are aluminum. As far as your stripped front pulley , a wise decision would be to replace that main gear as well, ask me why I know, after replacing 2 more pulleys.
