oil weight
Old Oct 3, 2016 | 09:23 AM
  #31
Weavr99FLHT's Avatar
Weavr99FLHT
Originally Posted by hotrod351
dont think i can go to auto parts and grab a quart of amsoil off the shelve. maybe i just buy HD brand.
I can get Amsoil at a local convenience store.
Old Oct 3, 2016 | 09:26 AM
  #32
hotrod351's Avatar
hotrod351
well neither autozone or orielys carry it. going to have to use multi mobil one.
Old Oct 3, 2016 | 09:35 AM
  #33
fat_tony's Avatar
fat_tony
All multigrade oils are made from a single weight base oil + an additive package. Single weight base oils will have there viscosity within a certain set range at different temperatures. All oils get thinner or have reduced viscosity as tempature increases.
The lower number, 20W, in this case is the weight of the single weight base oil. The higher number is obtained by adding polymers, which are part of the additive package, which act with heat to keep the oil from only thinning as much as a 50W or 60W base oil as the engine runs at operating tempature.
Old Oct 3, 2016 | 09:40 AM
  #34
hotrod351's Avatar
hotrod351
what i do remember is a engine i had that when i changed oil i put straight 30wt, lost almost 10 psi oil pressure, then went to 20-50wt and picked the pressure back up.
Old Oct 3, 2016 | 09:41 AM
  #35
hotrod351's Avatar
hotrod351
most of my ridding will be in 80 degrees and below, i dont ride when its 110 degrees outside. in fact its riding time now here in Arizona.
Old Oct 3, 2016 | 01:02 PM
  #36
Victor Tornado's Avatar
Victor Tornado
2nd Gear
I went with the Original synthetic, that being Amsoil. Runs cooler and quieter in my '06 S/G....and it can be used in the tranny! Great stuff.
Old Oct 3, 2016 | 02:12 PM
  #37
skratch's Avatar
skratch
and if you order in the next 10 minutes, you can get two for the price of one.......
Old Oct 3, 2016 | 03:38 PM
  #38
81rat's Avatar
81rat
I agree with fat_tony 100% as polymers do thicken oil , in fact I use 20w/50 and addd 1 bottle of STP ( which has a lot of polymers ) at oil change in summer as told to do so by a oil co Rep , so I have my cold start and 60wt
Old Oct 3, 2016 | 03:47 PM
  #39
Victor Tornado
2nd Gear
Sorry, not trying to be a smart axe.
Old Oct 3, 2016 | 04:48 PM
  #40
Tired's Avatar
Tired
Nothing original about that stuff. They buy from oil companies and blend. Do a little history digging. Synthetic oil was around many, many years prior to Amsoil. For example, Hitler had a big program developing and using syn oil for vehicles on the cold ***, eastern front.
