Road King Speedo Relocation
Old Oct 4, 2016 | 11:08 AM
14GuineaPig's Avatar
14GuineaPig
Max
I have too do some research to see if I can find any info about the speedo relocation. From looking at the photo in the 2014 Police catalog it appears that the indicator lights for the turn signals are still on the tank console, just below what is now the tach.
https://www.harley-davidson.com/en_U...alog.FINAL.pdf
Just saw Kuma's post and it may answer your questions. Looks like ReidRik Von has done a similar type mod.
Old Oct 4, 2016 | 11:13 AM
Campy Roadie's Avatar
Campy Roadie
Originally Posted by 14GuineaPig
Max
It'd solve part of the problem anyway. If it was just a plug up operation I might be able to rig an LED up on the handlebar clamp for the blinkers.
Old Oct 4, 2016 | 11:14 AM
Joe12RK's Avatar
Joe12RK
The beauty of Harleys is everything can be swapped around with a little ingenuity. It looks like the cop speedo (or tach) mounts to the handlebar clamp similar to your FXD or at least a Sportster. Why not get a speedo from one of the other models that mount there? The mounting bracket will have holes for all the indicator lights including turn signals. The electrical part may be difficult as the computer controls the speedo and odometer and will probably freak out if it thinks it's hooked up to a sportster speedo!
Campy Roadie
That guy didn't take no for an answer! I have to look at that thread and see what differences are in the two harnesses (police vs non police).
Thank you.
Old Oct 4, 2016 | 11:15 AM
Campy Roadie
Originally Posted by todd-67
Skully makes a full face with an integrated heads up display.
https://www.skully.com/
Skully went **** up.
Old Oct 4, 2016 | 11:16 AM
14GuineaPig
Read Kuma's post and look what ReidRik did .... includes turn signal indicator from what I can see in the picture.
Old Oct 4, 2016 | 11:24 AM
joemadd71's Avatar
joemadd71
His set up looks great, I think I would like something like that but with only one pod. Maybe one of the speedo's with RPG integrated...
Old Oct 4, 2016 | 11:26 AM
heavypic's Avatar
heavypic
OP -
A tank lift (front only) might work to put the speedo in your peripheral vision. You only need to see the relative position of the speedo needle in your peripheral vision to know your speed...fine details are not necessary. This is a cheap/easy fix and will help you keep your eyes on the road.
I did a 2" tank lift on a '04 Fat Boy I once had (see attached pics). The lift was just enough to spot the speedo while riding. The other benefit was rocker covers were easier to clean, more air to top of motor, and folks couldn't figure out why my FB looked different in a good way until I pointed out the lift.
I'm considering a 1.5-2" lift for my '14 Road King for the same reasons. I've seen 3" lift kits, but that's too high in my opinion. I want the lift for the stated benefits without it being too obvious the lift was done. See attached pic I downloaded of a member's RG model with a 2" lift. DK Customs and others make the lift kits, or you can make it yourself to your custom height with some metal stock, drill, grinder, paint and hardware. More info and pics on the net and this forum if you search.
Good luck
Attached Thumbnails Road King Speedo Relocation-hpim0329.jpg   Road King Speedo Relocation-hpim0330.jpg   Road King Speedo Relocation-tank-lift-3-2-inches.jpg
Old Oct 4, 2016 | 12:09 PM
Campy Roadie
My speedo is the digital one with a needle tach on top an digital readout on the bottom. The tank lift idea is a good one but I go 200 miles between stops when traveling. In my experience the fuel capacity is reduced; is that right?
I'm going to study the thread where he put everything up on the clamp. It looks like some work but the finished product is worth it.
Old Oct 4, 2016 | 03:39 PM
todd-67's Avatar
todd-67
Did not know that. I was wondering why the web site was a little jacked up. I only wear a bucket when traveling so i don't really keep up on them. Tnx for the info though.
