Lithium Battery
For those that don't know, you can't use these batteries with a "smart" charger or tender because these devices try to de-sulphate the lead acid plates. This type of action is lead acid specific and affects the LI batteries negatively.
If they were to make a bike or car charging system LI specific, they simply would move the circuitry embedded in the LI battery into the bikes charging system. In other words the charging system itself would only be added to anyway. Better to have a charging system that can accommodate either tech as opposed to being tech specific.
LI technology is emerging, and is getting better with every new iteration. If weight is an issue in your bike, then get an LI battery. For me, I haven't had to replace a bike battery in so long LI wasn't even available. Rest assured that although I haven't ever purchased one, I know plenty about the tech and how it's applied.
I have upgraded my level of concern on this issue to "Beer Can" level.
Made in USA
http://www.batterymart.com/p-Big-Cra...L-Battery.html
is going on 6 years and is still going strong.
Of course if not running it's at home in the garage on the tender which I believes contributes the longevity of it as well.
As mentioned earlier, they may be the way of the future, But I am going to wait a little while. Have at it, gentlemen...
Made in USA
Same ETX30L 400cca battery from the actual mfg/Deka for $98/approx $11 less to you door.
http://www.techbatterysolutions.com/...?Search=ETX30L
Scott
Here ya go,copy this link & info for future ref.
1 of the best prices i have seen on the battery you said your going with next time around.
YUASA'S GYZ32HL / 500CCA MAINT FREE FACT ACTIVATED AGM BATTERY FOR HD TOURING BIKES FOR ONLY $132 TO YOU DOOR VS RETAIL @ APPROX $200+.
Scott
http://www.phatperformanceparts.com/...arch.y=11&mfg=
