Battery Time?
If possible pull the battery from bike so it doesnt go dead & freeze ,crack and then leak some acid on bike as it warms up,wires,etc.
Also,when its time to get a battery heres a couple great buys on long lasting powerfull agm's for your touring HD.
* DEKA ETX30L/400CCA'S FOR $98 TO YOUR DOOR FROM " HIGH-TECH BATTERY " ONLINE.
* YUASA GYZ32HL/500CCA'S FOR $132 TO YOUR DOOR FROM " PHATPERF " ONLINE.
BTW,if your Roadking uses the smaller ETX20L series type battery they are also avail @ great prices from the same 2 sources.
Scott
The LIon batteries are great, IME.
So would it be safe to say the original maint free HD AGM battery in your 2013 hd lasted approx 3.5 yrs so using a tender/float charger very often?
If thats the case it's ok but not great either considering more then a few guys get 5-5.5yrs (even 6yrs) out of stock HD and or aftermarket (Deka or Yuasa) AGM batterie in their HD without using a maint/float charger other then once in a while in off season storage to top off the battery charge.
It make me thing maybe float charger was holding battery at a bit higher voltage then it should reducing it's srv'c life a bit.
Try this on your new battery to see if it will extend the life of your new battery.
When ever you decide to hook up the maint/float charger in season or in off season storage (if applicable) is to remove the maint/float charger ASAP (max of 24hrs) after the battery has reached full charge & gone to float mode.
Reason i suggest that is flaot charger i tested help my bikes agm battery at 13.1-13.2 volts for days after it reached full charge and went to float mode which short term day ot maybe 2 would kill it.
But i feel the float mode keeping the battery at 13.1-13.2v's day after day 24/7 wk after wk can in some cases over charge & or overheat the battery leading to premature failure.
I have seen that happen 1st hand more then just a couple times over the yr's when people were using maint/float chargers on their batteries 24/7 or often.
I have always done that type battery maint on my motorcycles & classic car & gotten considerably longer then avg srv'c life out of the batteries in those vehicles using that type battery charge/maint strategy.
Happy Motoring!
Scott
