Replacing headlight assembly
Old Nov 15, 2016 | 01:58 PM
HD32141's Avatar
HD32141
Default Replacing headlight assembly
My highbeam has quit and the lense has a few frosty lines. I want a new assembly. The oem part number is 68342-05A. What are my options for replacing it?
Old Nov 15, 2016 | 02:14 PM
dsigrist's Avatar
dsigrist
Switch to LEDs; Daymakers (HD) or Truck-Lite. You will not believe the amount of light they put out. There are two versions, projector and reflector. I personally like the projector version but there are tons of reviews out there. Install in plug and play.
Old Nov 15, 2016 | 02:25 PM
mkguitar's Avatar
mkguitar
budget choice- same again- alot of riders have them sitting in the box and you can buy cheap ( i put 2 in my 1974 Blazer).
the dual halogen can also be inexpensive- requires a wiring adapter or splice.
that's what I now use on my 09.
I'm not big on the leds- I think many of them don't cast an even light
mike
Old Nov 15, 2016 | 02:35 PM
HD32141's Avatar
HD32141
Any chance you have part numbers? I need one quick and don't have time to research... thanks!
Old Nov 15, 2016 | 02:50 PM
grbrown's Avatar
grbrown
Avoid replacement LED bulbs, they in particular are infamous for failing to provide a decent beam and causing dazzle. Any 7" round auto reflector will fit, it doesn't have to be fancy, as will any suitable normal auto bulb. If you are in a hurry just visit a decent auto parts store. Take your old unit, just to satisfy yourself the new one is the same.
There are good quality reflectors, especially E marked ones (European), which give excellent beam shape, from the likes of Bosch, Hella and Valeo. Branded bulbs will give best results, such as Osram.
I have Trucklight LED units in all three front lights, which are also widely available, which you may find locally. Here in the UK they are marketted for the off-road crowd for some reason, if that is any help!
Old Dec 13, 2016 | 08:55 AM
HD32141's Avatar
HD32141
Thanks
DCrider132
Aug 19, 2016 02:18 PM
ScoobyDooHarley
2014-2024 Touring Models
Jul 17, 2016 04:42 PM
steveg56
24
May 19, 2016 08:02 AM
starbiker99
Jul 1, 2015 02:01 PM
JerrySC
Product Reviews
Oct 14, 2006 10:59 PM
