Cam chain tensioners
Old Dec 19, 2016 | 02:13 PM
Tracker1's Avatar
Tracker1
Default Cam chain tensioners
I have 40,000 on a 03 RK I picked up in the spring. After not having a HD for over 20 years I have been educating myself both in the saddle and mechanically.
First thing I learned was change out the tensioners. So that will be my first project. Then the loose shifter arm off the tranny.
Looking around I see people talking about a using a non HD shoe. My thoughts is the originals have 40,000 on them,should I just use stock shoes?
I used to work on my own bikes but that was years ago and those were shovel heads, I see much has changed.
Old Dec 19, 2016 | 02:52 PM
dawg's Avatar
dawg
http://www.harleydavidsontensioner.com Cyco
Old Dec 19, 2016 | 04:04 PM
GRWHD's Avatar
GRWHD
Originally Posted by dawg
I used the Cyco on my 01.
Old Dec 19, 2016 | 04:18 PM
grbrown's Avatar
grbrown
If you plan on doing the work yourself do start by buying a factory service manual, as the contents of the cam chest have changed a bit since your shovel! With that mileage it is quite possible a PO has already been in there and upgraded in some way, so I suggest you hold back from buying any parts until you have taken a look inside. In addition to replacing the tensioners, upgrade options include replacing the entire cam plate, there being H-D and aftermarket versions, even a gear-drive set-up. You may be lucky and find you have to nothing more than seal it back up!
Old Dec 19, 2016 | 06:51 PM
Tracker1's Avatar
Tracker1
I am not buying any parts until I open it up and inspect, with my fingers crossed. I would like to hold off until my funds are better so I can look at cams, bearings, and lifters. If I find the tensioners need replaced I am going to have to just replace the tensioners and pushrods (to adjustables) and go back in later for other new parts. A manual is on its way.
Old Dec 19, 2016 | 07:25 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
I changed (well the shop did) my cam chain shoes at 22K and then again at 44k. The second time I upgraded to the hybrid cam plate from HD. This plate has hyd. cam chain shoes and incorporates a higher volume oil pump. I figure this will be my last time in the cam chest. Check it out, many will suggest a gear drive if your crankshaft run out is within tolerance. Good luck.
Old Dec 19, 2016 | 07:33 PM
twistedcherokee's Avatar
twistedcherokee
Only problem I had with CYCO & harleydavidsontensioners.com is in the instructions, they have the shoe on incorrectly in one of the photos. I told them about it and they did nothing to correct it last time I checked. I have a new tensioner & the shoes with the tooling (I went with gear drive instead) when I installed the shoe on as it was in the pic & then turned the page & found it was on wrong, I bought a new one from HD because I tweaked the metal portion trying to get it back apart. Both mine were stock when I replaced them at 50K & then at 100K (went gear dive then)
http://www.harleydavidsontensioner.com/replaceshoe.html
If you look at the spring and where it hits the shoe you can see that it is wrong. Pics 6&7 are wrong & 8 is right
Toby
Old Dec 19, 2016 | 07:43 PM
Campy Roadie's Avatar
Campy Roadie
I'm a Cyco shoe and stock oil pump man myself.
Old Dec 19, 2016 | 08:35 PM
chief08's Avatar
chief08
I used cyco shoes only got 34000 out of them. got more out of stock shoes 44000.cyco were wore down to metal . stock shoes were only wore half way
Old Dec 19, 2016 | 09:36 PM
Tracker1's Avatar
Tracker1
So what do I get from the HD dealer, just the shoes or shoes and springs?
