Hey guys its been a while since I've done a winter project. I have a '14 SGS as you know the dash switch panel has blanks. I was getting ready to order the auxiliary power switch kit http://www.harley-davidson.com/store...-fairing-mount which comes with a power harness. I pulled dash switch panel and to my surprise there are power harnesses plugged into the blanks on each side see pic below. Can anyone tell me where the other end of those harnesses are to plug in your power accessories?
Let me word my question a different way I want to have a dash switch to a powered accessory in my saddle bag . If anyone could walk me through this it would be greatly appreciated!
Thanks in advance
Ed.
Not completely sure on the 2014 as I have a 2011. But. There is one under the fairing. One under the seat. One in the rear fender. Other than that not sure. Where you want to terminate a device or accessory Harley sells a pig tail/adapter to add you accessory of choice.Good Luck.
The plug is under the left side cover. I really can't tell you exactly which wire goes to which switch. There are 8 wires going in to the plug. Hope this helps a bit.
And after reading the post from @GlidingJoe he did a great job of mapping out the wiring but what really had me confused was the service manual's illustration of the fuse box area shows two connections below the fuse box the upper one for diagnostics and the lower one for accessories well mine were in the opposite position to what the manual shows and I never would have figured that out without Joes wire color info !
Just install the switches in the dash the plug is already in place and plug the included wire harnesses in the kit to the accessory outlet below the fuse box and hook your accessory up to the harness and bingo its wired to the dash switch!
The harness that comes with the kit is setup with different options. One set of wires will handle a load of 2amp, the other set of wires are configured with a relay for larger amp draw accessories. Just a heads up.
Yes I need the larger than 2amp to power a small compressor.
