Lift table
I've gone down the HF modification road and didn't like it. Spent as much in parts (hydraulic pump, pump base, foot pedal, etc,) and wasted time as I did on the $299 table. And in the end the table will never be as sound as the one I have now.
I decided that I was going to bite the bullet and buy a Handy Lift, which is what most bike shops use, at least in my experience. A few months religiously scanning Craigslist and I was able to snag a decent deal on one, but it was still high (about $750). I've never regretted spending that money though for a quality lift that I don't have to worry about.
I've since fitted it with the side boards, which allows me to run my ATV's up on it for their maintenance as well. (also makes getting on/off the bike much easier)
Money well spent in my book.
Steve
There seems to be a "get what you pay for" theme among the lift tables. What you are willing to accept, the "cost v benefit" if you will, is going to vary between each of us... if a Harbor Freight table will work for you, great, but don't try to talk yourself into thinking a HF table is the same quality as a top model Handy, K&L, or Titan, that's just not the case...
I wanted a lift that was rated for my Ultra limited (900lbs) plus some. When you are wrenching on a comp bolt with a cheater bar, stability and strength matter. I decided I wanted over a 1000lb max limit. I also wanted a table that went to 40" from the floor, rather than the standard 32"...
I was between a Handy B.O.B. (1500lb max) or the K&L MC625R (1750lbs). I liked that the K&L had twin cylinders, and the scissor mechanism rolls on a metal frame, not directly on the concrete floor.
I got a deal on a K&L, for about $300 less than a similarly equipped Handy. It wasn't cheap, but it is a quality lift, that will out live me. I 'd rather do it right the first time...
Good luck on your decision.... whatever lift table you select, they are an excellent tool... not to mention a back saver....
Nice lift and workspace, hattitude. Wish mine were less cluttered.
Steve
I've been riding Harleys since 1977. I have worked on my bikes in parking lots, on concrete patios, in a 10x10 tuff shed, in friend's garages, done several oil changes while parked on the street, and finally had a garage of my own.
I had to share the garage with two Great Danes, washer/dryer, and misc garage stuff...
When I retired a couple years ago, the wife was cool with me building a small 360 sq. ft. shop for me and my Harleys....
My bikes and I have come a long way..
