Handlebar question
Old Feb 11, 2017 | 09:47 PM
tsc0789's Avatar
tsc0789
Default Handlebar question
i have a 2017 CVO limited and I installed Khrome Werks +2 narrow sweepers #300518 on my bike. Went riding today and a buddy of mine tried them out and wants me to install a set on his bike, he has a 2012 limited
My question is has anyone installed these bars on the same bike and did you have to change any cables or add wire extensions
Thanks
Terence
Old Feb 11, 2017 | 09:52 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
its not as easy as your 17,cables and hoses should be good but btw can be a challenge.
bigdumbnoitall00
tbw damm spell check.
Old Feb 11, 2017 | 10:31 PM
mkguitar's Avatar
mkguitar
2009 flhtc, I did the 300077 2+2 and the only change will be the clutch cable- I have not yet swapped the cable, mine is re-routed but it is ugly.
all the wiring will be good....not sure about your heated grips though
the brake lever requires a shim be applied to prevent the switch breaking...this will give the system positive pressure.
you may need to slightly loosen the brake line fitting and adjust the angle, have a rag ready the catch any seep.
mike
tsc0789
Apr 16, 2018 12:12 PM
laduckslayer
Nov 2, 2014 12:55 PM
Road Star
Jan 23, 2014 12:21 AM
Hayhoss
Oct 21, 2011 05:49 PM
Hoffy
Nov 27, 2008 07:53 PM
