Rear Brakes
Old Feb 15, 2017 | 11:23 PM
Axemen1661's Avatar
Axemen1661
Stage III
Default Rear Brakes
Last fall, My rear brake pedal did some funky Sh*t. Id press on it and nothing, it felt like I had to pump it to work. That happened a few times. I started it up today and now the pedal wont move and have no rear brakes at all... Whatya think?
Old Feb 15, 2017 | 11:59 PM
svarnster's Avatar
svarnster
brake master cylinder , I would see if it needs to be cleaned or if the pivot point needs to be greased or cleaned. that's where I would start
Old Feb 16, 2017 | 12:25 AM
mkguitar's Avatar
mkguitar
could be water frozen in the lines.
moisture will collect in a brake system over time and i'm guessing that with the brake failure last fall, you are ready to re and re the whole system
Mike
Old Feb 16, 2017 | 07:13 AM
GRWHD's Avatar
GRWHD
Does you bike have ABS?
If it does there could be more to it.
Old Feb 16, 2017 | 09:05 AM
sfchief's Avatar
sfchief
Check to see if your bike was recalled for the rear brake light switch.
Old Feb 16, 2017 | 09:25 AM
svarnster's Avatar
svarnster
check the fluid level in the rear master cylinder, as per the pumping the brake is a sign of air in the system,and look for leak around rear caliper
Old Feb 16, 2017 | 03:28 PM
btsom's Avatar
btsom
A locked lever or pedal is THE CLASSIC symptom of an ABS unit failure. No information about what you ride so not much more to say.
Krugermeier
Feb 22, 2020 01:10 PM
mfd#1
Jul 30, 2018 08:56 AM
Lt Meat
Apr 24, 2016 03:35 AM
BuzzMe
May 26, 2015 08:07 AM
Daytona Glider
Wheels/Tires
Jul 9, 2013 08:49 AM
