Tail Light
Old Feb 16, 2017 | 04:27 PM
Railhead's Avatar
Railhead
Stage I
Default Tail Light
Lost the tail light on '08 FLTR. Brake light works fine. It's not the bulb. No apparent damage to wires or plug
Old Feb 16, 2017 | 04:30 PM
mkguitar's Avatar
mkguitar
power for the run light circuit comes up the blue wire, you can test that ( red/yel brake, black ground, brn and violet are turns) behind the tail light where it plugs into the board.
if bike is lowered, check that a bottoming out tire hasn;t eaten the wiring
test point at the plug under the seat at the front of the fender
fuse? the 15A lights fuse also has the front running lights on it
bulb? more than once it has been the bulb, there are 2 filaments and one can break and even short out on the other
welcome to the forums
Mike
Old Feb 16, 2017 | 05:06 PM
BackRoader's Avatar
BackRoader
I am assuming you are using your foot brake pedal. Check and see if it works when you use the hand brake lever. If so, its your brake light switch. Its located down near your exhaust below the seat area. It is installed in the brake line which runs along the frame, and is actuated by brake fluid pressure. Not hard to change out. Have to bleed rear brake after install. Ask me how I know.
Old Feb 16, 2017 | 05:10 PM
BackRoader's Avatar
BackRoader
Sorry, should have paid more attention to your thread. You said you have brake light, but no tail. Forget my previous post and welcome to the forum. If you cant figure it out you can bet someone here will help you solve it.
Damien Bessent
Sep 20, 2022 03:36 PM
Hades02
Electrical/Lighting/Alarm
16
Oct 19, 2017 04:27 PM
RoadHog659
Nov 30, 2014 04:35 PM
Back Roads
Jul 8, 2012 07:45 PM
spdmtlrcng
Apr 1, 2012 10:34 PM
