headlight and running light upgrade
Old Feb 26, 2017 | 04:49 PM
scg's Avatar
scg
Default headlight and running light upgrade
just wondering whats available now from stock '96 Roadking lighting
Old Feb 26, 2017 | 05:00 PM
mkguitar's Avatar
mkguitar
you could get a late model ( 05+) reflector that uses the same H4 bulb like you have now- the optics are very good.( 68342-05)
you could get a dual halogen ( 67700062) and do a little wiring work- optics, light output and beam control very good.
- these both show up on the classifieds
you could get online HID kits ( your radio may not work anymore)
or "led" kits which in many cases throw gobs of uncontrolled light with hotspots, glare shadows etc. these capsules fit in your reflector
or buy full on LEDs from HD, JWSpeaker, or trucklite
I think these all make for a lack of visibility in traffic.
I use the Dual halogen on my 09. the stock reflector from the 09 went in my 74 blazer (along with another I bought ) another late model reflector is in my '53.
all the FL bikes since 1949 use a 7" headlight and are physically interchangeable- may need some wiring changes
mike
Old Feb 26, 2017 | 05:40 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
socalmotogear has a nice hid kit u can get it with led passing lamp bulbs with the same color temp as the hid, ad a hella e-code headlight bucket for about 40$ it tightens up the headlight been.
Old Feb 26, 2017 | 06:39 PM
OldPhat's Avatar
OldPhat
Mike is correct, again.
I had a 07 Road King Custom, and did lots of riding in the dark, so I added the Dual Bulb Halogen headlamp to the RK.
That made a big differences, after a few adjustments, for my ride to work at 5AM in the mornings.
Your results may be different with some lights.
John
Old Mar 3, 2017 | 08:14 AM
stan leiter's Avatar
stan leiter
Stage I
First post so forgive me if i am doing it wrong.I am upgrading my 1997 ultra headlight to a 2015 dual halogen.I hooked it to my original 3 prong plug.it works however when i turn on high beam the low beam bulb goes out.I see in the upgrade kit from harley they include a new harness from the light to the 3 prong plug.i am thinking i need to run a jumper wire some place.i am trying to do this without buying the,i am sure overpriced harness from harley.any help is greatly appreciated.thank you
Old Mar 3, 2017 | 08:27 AM
Buelligan666's Avatar
Buelligan666
You need to wire in a relay. Here's a post I made about it.
https://www.hdforums.com/forum/showp...3&postcount=37
Old Mar 3, 2017 | 11:05 PM
WesM's Avatar
WesM
I bought a set of sunpie lights off amazon. I could not be more pleased
Dynafrom818
Nov 27, 2012 02:20 PM
frenchbiker
Sep 2, 2012 12:19 PM
Estil
Jan 29, 2012 12:59 PM
cptdenny
Jan 26, 2011 12:32 PM
Dannell53
Jan 22, 2011 10:23 PM
