ignition switch ,problem
Old Feb 26, 2017 | 05:32 PM
Texas Wood's Avatar
Texas Wood
6th Gear
Default ignition switch ,problem
09 FLHX I'm trying to put the ignition switch back in place but for some reason when I drop it back down in will not drop "all" the way back down. I have the forks locked. It drops down the first notch but won't drop in the last one, is there a certain combination I am not getting ?
Old Feb 26, 2017 | 05:44 PM
TSheff's Avatar
TSheff
Did you follow the Service manual procedure to remove it and are you using the alignment tool?
Old Feb 26, 2017 | 06:14 PM
Texas Wood's Avatar
Texas Wood
6th Gear
yes, but I'm not sure alignment is the problem. I could take the nut off the top of the switch and it drops right in and works fine, It just seems the ignition switch when I turn it to unlock it wont pull the latch back far enough to let it drop
Old Feb 26, 2017 | 06:18 PM
TSheff's Avatar
TSheff
Did you try moving the handlebars slightly?
Old Feb 26, 2017 | 06:23 PM
Texas Wood's Avatar
Texas Wood
6th Gear
I got it,I turned it to unlock and pushed the detent button down it set all the way open dropped right in Thanks for the help
Old Feb 26, 2017 | 06:33 PM
TSheff's Avatar
TSheff
Good deal, Welcome to the Forum, and always post final results (as you did).
Texas?? Big State
gsbuick65
Jul 17, 2018 01:58 PM
bearammus
Mar 6, 2014 08:08 PM
mcso
Aug 10, 2012 03:03 PM
cmeans
EVO
Jun 13, 2011 10:36 PM
SparkyRKM
Aug 29, 2007 12:42 PM
