yes.....I got a great loping awesome idle after warmup. Remember, after going to stage 2......cams, and pull-push more air, the tune is the key. I sent a request to V&H, got a fast reply from Cheyne. He sent me a custom tune after stage 1 and 2. Working on my auto tune now from my stage 2 base map. V&H did a great job. Once you marry the fp3 to the bike, you send your vin to them. They can upload you a tune in seconds after it's built. You will have to send them the specs on the cams. Lift/duration specs that is......Very happy with the entire process!
Well not everyone will need a tune...
B Bop
2012 FLHR (Road King) Ember Red Sunglo & Merlo Cruise Control, ABS, Chrome Aluminum Profile Laced Spoke Tubeless Wheels, Security Package, Saddle Bag LED Lid Spoilers, and an array of accessories that enhances nostalgic appearance & blood curdling performance.
The beauty of the Second Amendment is that it will not be needed until they try to take it.
Check with Vance and Hines if you got their exhaust ask them about cams they would suggest and matched with the fp3 they have synonyms sheets on many combinations
Check with Vance and Hines if you got their exhaust ask them about cams they would suggest and matched with the fp3 they have dyno sheets on many combinations
I had Andrews 57H, propipe, Ness A/C, SERT, and Dyno tune done at my local dealer in the fall of 2015. They charged me $1300. I ended up with 97hp/108tq. I've been very happy with my 13 RK performance. This year will focus on suspension.
I have the Vance and Hines Xpipe, Monsta Round slipons, hiflow ac, Harley tuner (the one that's banned) and a 259e cam in a 14 limited. The bike runs like a scalded dog. It climbs hills like a beast.
Reason: sentence stucture
Sounds like a nice strong setup, who did the work?
I just rebuilt my 103 to 10.2-1 comp and running Andrews 54's. They hit about 2700 rpm and pull to 5400. That is RIGHT where I ride. The hit is not hard but it is steady. If you do a lot of longer distance riding, I would suggest the 54s over the 57s. The 57s hit hard but drop off hard. I had the opportunity to test ride 2 bikes with the same piston set up but the two different cams. I liked the overall performance of the 54s.
