Need help - Broken volume control replacement
Old Mar 5, 2017 | 08:27 AM
Hades02's Avatar
Hades02
Default Need help - Broken volume control replacement
So one day on the road, I went to lower my radio using the thumb control and I felt a dreaded click. I broke the volume switch inside the housing. I ordered the part, which has been superseded, and the wire colors do not match. The only markings on both switches are some numbers stamped on one side on each switch. Common sense would tell me to orient the numbers in the same direction and cut and splice the wires together.
The switch does not come with instructions, the service manual does not cover this and a google search yielded no results.
Need your help if you have gone through this or have some insight.
Old Mar 5, 2017 | 09:18 AM
Boomer1143's Avatar
Boomer1143
I would think this would be covered in the electrical / electronics manual. What year and model of bike?
Old Mar 5, 2017 | 09:33 AM
ORradtech's Avatar
ORradtech
How many wires on each switch?
A pic of them side by side may help.
Old Mar 5, 2017 | 09:35 AM
Boomer1143's Avatar
Boomer1143
I have the 2012 electronics manual. Getting copies to scan is difficult but hopefully this will help.
Old Mar 5, 2017 | 10:11 AM
mkguitar's Avatar
mkguitar
I just did mine.
first off what year bike and model?
2 ensure that you have the correct side switch- the left and right side switches are functionally the same, but use different wire coding and the index for the **** is 180ş off.
it can be used but you have to translate the wire codes and the **** will be upside down.
for my 09 model the correct switch was the correct colours.
GY/GN
GN/BE
PK/WE
BN/BK
the service manual will not only show the colours used for wiring but also shows the switch functions ( what happens with contact from say pink/white t grey/green...vol - )
Mike
Old Mar 5, 2017 | 10:22 AM
14GuineaPig's Avatar
14GuineaPig
The original part # was 71619-98 that was replaced with 71810-08.
I checked wiring diagrams for a 2002 FLHTC, 2009 FLHX & 2013 FLHX and all are using the same wire colors for the audio switch. Are you sure they gave you the correct switch? It would be very odd to change the wire colors.
According to wiring diagrams both the old 71619-98 & the new 71810-08 use the same color wires.
Old Mar 5, 2017 | 10:39 AM
mkguitar's Avatar
mkguitar
this is my experience
from my fixin' it post:
the instructions to replace switch in the manual have the old wires cut near the switch and the new switch wires soldered on, shrink and route the wires so they'll fit in the housing- I do not solder on vehicles and have learned the hard way this don;t work well over time.
So...snipped the wires at the old switch. the wires with the new switch are plenty long- I stripped each back 1/2" and soldered pink to pink green to green etc, and pulled the new wires through the sheath .
once I had everything pulled through and put the controls back together ala manual, I cut each of the 8 wires to about 3". stripped and crimped 4 times, and taped up the bundle with a tie wrap to keep it all tight.
mike
Old Mar 5, 2017 | 02:54 PM
Hades02's Avatar
Hades02
2009 Streetglide but I added the electraglide left switch housing to add PTT for my air ride.
The origignal is 71619-98. I ordered 71642-08 thinking that the switch was a little smaller as the old switch did not want to sit right when I put it all back together. Now, it did not break because of this. It broke because of me forcing on the new chrome buttons. Those of you that have put on the chrome switch caps can attest what a pita it is. The colors on the new switch are
Grey/Green
Pink/White
Purple/black
Green/blue
Old Mar 5, 2017 | 03:09 PM
Hades02's Avatar
Hades02
Pic of new switch
Old Mar 5, 2017 | 05:08 PM
mkguitar's Avatar
mkguitar
as above, mine was different part number.
also had instructions and new pins for the connector
Mike
