Lessons Learned from a Newbie Wrench...
Old Jun 1, 2007 | 08:17 PM
tizone's Avatar
tizone
Default Lessons Learned from a Newbie Wrench...
I have owned many bikes and worked on none myself... Until today. With my trusty HD toolkit I removed the outer fairing and upgraded my fairing speakers to J&M, I upgraded the rears as well... then I removed the seat and installed a charging harness on the battery... sounds easy right?
Here is what I learned.
Removing the outer fairing with the advice on this forum was easy...
The screws holding the stock speakers in were freakin tight! But instalation of the new ones was easy.
Replacing the fairing went well but as noted in previous posts it is very easy to cross thread those copper inserts... gotta be patient.
Removing the seat was easy.
Getting the battery out of that tiny little hole is a royal PIA! Damn! And you can't undo the ground nut unless you get the battery up out of that freakin hole!
Putting the seat back on was another pain. Getting the back of the seat to line up with the mounting screw hole is tricky business. I had the tongue inserted properly but trying to get that bolt back in is tough unless you have long, wirey fingers.
All i all a good day. I think I could remove that fairing much quicker now that I know what I am doing. And I will have to do so soon because my Zumo showed up today!!!
Old Jun 1, 2007 | 08:19 PM
PapaTravis's Avatar
PapaTravis
Default RE: Lessons Learned from a Newbie Wrench...
Good for you. Gotta save pennies where you can, for more upgrades.
Lunchboxx
May 10, 2016 11:49 AM
uwiik
Audio Systems
Nov 7, 2013 07:57 AM
ral819
Aug 4, 2011 05:46 AM
Purp
May 11, 2007 10:03 PM
bucs012
Aug 18, 2006 10:25 AM
