Finallyretired
Old Mar 10, 2017 | 12:36 PM
grtwtbuf1's Avatar
grtwtbuf1
Stage IV
Default Finallyretired
1998 UltraClassic, fuse for brake light / cruise control blows when turning ignition on. Disconnected wiring harness to rear light assembly still pops fuse, disconnected rear brake light switch still pops fuse. HELP, Please.
Old Mar 10, 2017 | 12:56 PM
gipper's Avatar
gipper
Misleading header.....
I was going to congratulate you.
Old Mar 10, 2017 | 01:26 PM
btsom's Avatar
btsom
Pull out the brake relay and try one more time. Fuse pops, short in control circuit, either from front brake lever or rear brake switch. Fuse doesn't pop, short is between the brake relay and the back of the bike.
Have you changed handle grips or otherwise fiddled with the front brake switch box and wires. Putting that all back together is usually when a wire gets pinched causing a short in the circuit that would trigger the brake relay.
Old Mar 10, 2017 | 01:50 PM
decencyxdefied's Avatar
decencyxdefied
Same here
Old Mar 10, 2017 | 02:06 PM
ORradtech's Avatar
ORradtech
What the heck does being retired have to do with a brake light fuse?
Buy a factory service manual and trace the wiring for your obvious short.
Old Mar 10, 2017 | 02:07 PM
grtwtbuf1's Avatar
grtwtbuf1
Stage IV
Change handle grips in 2006 brake light still work until recently. Had her in shop in 2015 for some work brake light still worked until recently. Disconnected wiring harness to rear and rear brake light switch still pops fuse. Will try your suggestion. will try over the weekend. Thank you for your advise.
Old Mar 10, 2017 | 02:17 PM
btsom's Avatar
btsom
I didn't notice brake/CRUISE CONTROL in your original post. Since turning on the ignition , not activating the front or rear brake, blows the fuse I am suspicious of a cruise circuit short because it has power available to the switch any time the ignition is on. Without a manual or someone with a manual for the same bike, this may get difficult.
Old Mar 10, 2017 | 06:52 PM
14GuineaPig's Avatar
14GuineaPig
That fuse send power out on a Orange/Violet stripe wire. It goes to the stop lamp relay.
It also goes to the interconnect harness and feeds the Cruise dash panel switch. It also goes to the Ultra Overlay harness for the Throttle Roll Off switch & cruise control module. It also goes to the console pod assembly.
Old Mar 10, 2017 | 10:17 PM
skeeter 250's Avatar
skeeter 250
I haven't worked since Jan 6th. Will be officially retired Mar. 28th. Op hopefully it is a simple fix
Lantern
Electrical/Lighting/Alarm
Jun 25, 2021 10:26 AM
pjchops
General Topics/Tech Tips
11
Aug 26, 2018 08:54 AM
clarkchriston
May 21, 2014 05:24 PM
twistedbluesteel
Jul 23, 2012 01:56 PM
tidefan60
Apr 23, 2010 01:45 AM
