Power under fairing
Old Mar 15, 2017 | 05:22 PM
NVERL8's Avatar
NVERL8
Default Power under fairing
Is there a good place to get a constant power source under the fairing? Not a key hot. I have the power wire for my amp up there direct from the battery but I don't think it's a good idea to run anything else off an amp power wire.
Old Mar 15, 2017 | 05:47 PM
TriGeezer's Avatar
TriGeezer
They"always hot" Len from the battery goes to the idnition switch. At can be accessed from inside the fairing. Don't cut it...but carefully peel off some insulation, wrap the bared wire around it and solder it. Wrap well with electric tape. Make sure to put a fuse inline to the wire you added. Use a DMM to to find the hot wire.
Old Mar 15, 2017 | 06:58 PM
NVERL8's Avatar
NVERL8
Anything not so critical as the ignition to tap into........
Old Mar 15, 2017 | 07:37 PM
mkguitar's Avatar
mkguitar
run from your amp wire...just add a fuse to match the load
Mike
User 11821
Audio Systems
Jul 9, 2017 05:39 PM
rs03371
Audio Systems
Sep 8, 2016 02:02 PM
Captnpirate
2014-2024 Touring Models
Oct 9, 2015 09:38 PM
tundrabuilt
Audio Systems
19
Oct 9, 2015 01:06 PM
MINI SSS
Apr 3, 2010 11:14 AM
