2007 Ultra cruise control issue
Old Mar 19, 2017 | 06:37 PM
kblhd's Avatar
kblhd
Default 2007 Ultra cruise control issue
Ride partners 2007 Ultra cruise control quit working along with brake lights and turn signals all at once. Flashers work when ignition switch is off. Any thoughts on what it might be? Fuse is good.
Old Mar 19, 2017 | 07:42 PM
ORradtech's Avatar
ORradtech
I would suspect that the cruise is fine and will begin working again when you get the brake and turns working again.
What I'd so is check all fuses for the lights, turn and brake relays and the wiring harnesses for damage.
Has he had any recent work done? Bars, new lights, etc?
Old Mar 19, 2017 | 08:31 PM
kblhd's Avatar
kblhd
Only recent activity was to take the fairing off to plug in the XM radio that had quit working.
Old Mar 19, 2017 | 08:35 PM
smitty901's Avatar
smitty901
Fuse check them one is popped. I know you said fuse is good check them again real good been there done that with my 07 .
Old Mar 19, 2017 | 09:03 PM
kblhd's Avatar
kblhd
Smitty901
Thanks will pass that along.
Old Mar 19, 2017 | 09:07 PM
chevelledude's Avatar
chevelledude
Brake lights and cruise are same fuse.
Old Mar 20, 2017 | 08:05 AM
14GuineaPig's Avatar
14GuineaPig
Check the ACC fuse. The brake light & turn signals are on that fuse.
Old Mar 20, 2017 | 10:04 PM
kblhd's Avatar
kblhd
YUP ended up being the ACC fuse. Now need to find out why it blew. Thanks to everyone for the reply's. Great forum .
Old Mar 20, 2017 | 11:31 PM
t. sawyer's Avatar
t. sawyer
warm your heart don't it? when everything works out good. the cost, bearable. yep, sorry partying a little. nite
kroozeabout.
Old Apr 7, 2017 | 10:22 PM
kblhd's Avatar
kblhd
The bike had been purchased used and the previous owner had installed an 18 rear tire instead of the factory 16 inch and the tire had rubbed through the wires to the rear tail light. Found it while replacing the rear tire.
