Another Aux switch question?
Old Mar 21, 2017 | 07:11 PM
Budda109's Avatar
Budda109
Default Another Aux switch question?
Have a friend who lives in another state. He has a 2013 Street Glide. He added the engine guard lights from Cirius. He bought the Harley part to connect under the seat and be controlled by the AUX switch. However if he plugs it in. It is on all the time. Switch does nothing. At first they were dim. He was told to flip the plug in. One side is 6VDC the other is 12 VDC. Neither works with the switch. At that point it was bright but still no response from switch? Any suggestions or thoughts? Thanks
Old Mar 21, 2017 | 07:18 PM
craigffb's Avatar
craigffb
He's got it wired wrong. The AUX plug under the seat has 4 wires...ignition hot, switched hot, brake hot, and ground. He just has it wired wrong.
davidwruth's Avatar
davidwruth
Is he sure he used the correct plug on the bike
Old Mar 21, 2017 | 07:20 PM
Toypuller's Avatar
Toypuller
The switch is bad, or you have a short.
6volts on the off position would indicate a short.
davidwruth's Avatar
davidwruth
Does he have a meter. It makes it a lot easier to figure out the correct wires
Old Mar 21, 2017 | 07:23 PM
Budda109's Avatar
Budda109
Default 6volts
He called the dealer was told the same plug works on 12 or 6 VDC. I do not believe he has a meter. I will try to make a trip and test it. Where is the plug that is connected to the AUX switch on the dash board?
Old Mar 21, 2017 | 07:26 PM
paid4c4's Avatar
paid4c4
What he said above. There is no 6volt source in the plug. Are you sure he is using the right plug, there are several in the same area by the battery.
Bill
Old Mar 21, 2017 | 08:10 PM
davidwruth's Avatar
davidwruth
Yes there are 4 wires in it
Old Mar 21, 2017 | 08:13 PM
mastergunnera8's Avatar
mastergunnera8
I was thinking of the more recent switch kit..is there a part number for the 2013 kit?
https://serviceinfo.harley-davidson....document/62026
Old Mar 21, 2017 | 08:15 PM
davidwruth's Avatar
davidwruth
Should look something like this
