slip ons with EFI ???
Old Oct 9, 2005 | 12:22 AM
blukrom's Avatar
blukrom
Default slip ons with EFI ???
I just put on my new V&H Oval slip ons..... Sounds great and runs good too, just a few gurgles when slowing down.
I havent done the intake or any downloads. I read here before that this shouldnt cause any trouble. But I would like to hear it again for my piece of mind.
I have a Big sucker sitting in the garage(not on the bike yet) and a DFO on order. I dont need to park it until the DFO comes do I?[&:]
Old Oct 9, 2005 | 12:33 AM
eg willy's Avatar
eg willy
Default RE: slip ons with EFI ???
You should be OK until you change the air intake....then you will be running leaner.
Old Oct 9, 2005 | 01:02 AM
luvmyflhtcui's Avatar
luvmyflhtcui
Your exhaust is fine as long as you don't install the breather. That will lean your bike way out and you stand a chance of burning a valve. You'll need an aftermarket ignition system or Harley download for your ECM. I like the Vance and Hnies slips-ons as well. Good luck.
[IMG]local://upfiles/494/14B3EA75842D4E4C9EFCCCB4C56FC5FB.jpg[/IMG]
Old Oct 9, 2005 | 01:19 AM
blukrom's Avatar
blukrom
Thanks guys that makes me feel better. Question though, once I install the DFO and intake will I still need to do a stage one flash of the ECM?
Old Oct 9, 2005 | 11:58 AM
mndemohead's Avatar
mndemohead
You will ned to reflash the e.c.m.
Old Oct 9, 2005 | 12:11 PM
HDF Tech's Avatar
HDF Tech
ORIGINAL: blukrom
Contrary to many beliefs, you do not need to reflash when using the DFO/TFI. The only benefit to the download (reflash) would be a higher rev limit, which on your bike would only spin the motor over higher (not a good thing with a TC) without any real benefit because you are already past the power band of the stock cam. Only other "benefit" of the reflash is if the DFO takes a dump, you'll still get a bit more fuel to the engine. The DFO is also more adjustable ( range wise) without the download and can be dialed in better. To date, I've never heard of a DFO taking a dump.
Old Oct 10, 2005 | 04:36 PM
blukrom's Avatar
blukrom
Thanks for the help. When I get the DFO installed is it a pretty straight forward adjustment procedure?
Old Oct 10, 2005 | 07:46 PM
screamn_eagle's Avatar
screamn_eagle
i really should just look around the forum, but WTF IS A DFO/TCI? please someone help.
Old Oct 10, 2005 | 08:42 PM
HDF Tech's Avatar
HDF Tech
ORIGINAL: blukrom
Take a look in the DIY forums, there's over 425 topics in there to help out with situations like this!
I'll even give you the forum for this here https://www.hdforums.com/forumid_247/tt.htm
Old Nov 19, 2005 | 02:58 AM
alarmguy's Avatar
alarmguy
6th Gear
I too, would like to know what DFO stands for, (I'm assuming that its an acronym ) It's too bad that some who have been here longer feel that it would be troublesome to be helpfull but instead, more eager to make reference to past discussion.
