Rush Big Louies
Old Mar 30, 2017 | 06:26 PM
damquick1's Avatar
damquick1
I had a catless header with 2.5 baffles and it was a nightmare to get it tuned correctly....if you remove the cat Rush recommends 2.0 baffles for no cat.....since I changed them the PV tune they loaded and a few auto tunes run and now it's golden...changing from 2.5 to 2.0 hardly did anything to the exhaust note...it actually sounds better, a bit lower growl and no drone at cruising, no decal pop.....I also installed a Cobra PowerPorts system, great exhaust...with that change it definitely reduced the leg burning effect on the right side, my GF says the rear heat is almost gone completely.....
Old Mar 30, 2017 | 10:04 PM
scooper321's Avatar
scooper321
I've got 2.5" baffles in my BL's on my 2007 RK (no cat head pipe). I had no idea I had no packing material in them until I bought material and went to repackage them. Yes, you read that right. Lol.
After repacking with 2 layers of fiber material the pipes sound crisper with more clear bark on accel. They probably are a little less loud overall but the only way I can tell is that I can hear my radio a little better. Otherwise, it sounds the same (but better, like I said).
I can't imagine running 3" with no cat. There'd be no back pressure and I think the bike would perform horribly.
Old Mar 31, 2017 | 05:24 AM
Hate Work's Avatar
Hate Work
Originally Posted by Deckman
I have the Big Louies with 2.5" baffles with cams and a 107 Big Bore and it is loud but not ear splitting. Best sound after trying about 6-7 other slip-ons. I would call Rush and ask them the best performing baffles for your bike. When I had the cams without the Big Bore Rush recommended the 2.25" for best performance.
This, For every engine/tube configuration, Rush has a "recommended" baffle size. Call them. It worked for me.
Labrador
Jun 5, 2018 05:36 PM
paulies 07
Jul 24, 2009 06:59 PM
Taterdigger
Jul 8, 2009 03:51 PM
bobros
Exhaust System Topics
Aug 16, 2007 05:13 PM
dchoran
Mar 8, 2007 12:08 AM
