2003 RKC PPU 51502 code?
Old Apr 2, 2017 | 03:35 PM
cajun1957a's Avatar
cajun1957a
Default 2003 RKC PPU 51502 code?
Does anyone know what PPU 51502 code. The engine light and keylight came on today. The speedo went goofy as well right after I washed it. Hint to self, Something may have got wet. But I go through the diagnostic codes and all ten are clear except after the tenth one A PPU appears then when I press the button 51502 comes up.
randy
Old Aug 1, 2018 | 12:45 AM
smccabe's Avatar
smccabe
4th Gear
Hi, I just made my first post, and it is in re; to same PPU 51502. Did you find out what it was all about and were you able to clear it?
Thanks, Smccabe
Old Aug 1, 2018 | 03:03 AM
Tarkus60's Avatar
Tarkus60
I think PPU has do to with the speedometer sensor...I just googled it so not sure.
My key light was coming on last year,I put a new battery in the Fob and reset the alarm.
Old Aug 1, 2018 | 07:34 AM
cajun1957a's Avatar
cajun1957a
I don't think I did anything. It went away shortly after. I honestly don't remember what caused it or what I did.
randy
Old Aug 1, 2018 | 09:42 PM
smccabe's Avatar
smccabe
4th Gear
That could be the easiest fix. Will try. Thanks!
Old Aug 2, 2018 | 11:34 PM
Owner's Avatar
Owner
Found this on a HD code search site, “codes most likely can’t be deciphered without the HD Electrical Diagnostics Code Manual”. ($129). I can’t find a pdf of that anywhere online..
From what I gathered while breezing over the lengthy write up, the letter represents a catagory, (P, U) the first two numbers place the code in its ranking (51 - current/historic), and the following numbers relate to the code definition.(502) VSS High Open can-bus
VSS Speed Failed Low
This should confuse everybody well enough..To be honest I’m not sure this is of any significance. The only part I really understand is, it’s $129 to get code definitions.. lol
Old Aug 3, 2018 | 06:40 AM
cajun1957a's Avatar
cajun1957a
I remember after researching my code issue was to turn the bike ignition on and off. I think it was like 50 times to clear any historically codes. After that I have never seen it since. I don't know what caused mine to initially cause it but its gone and has never returned.
randy
Old Aug 4, 2018 | 05:18 PM
smccabe's Avatar
smccabe
4th Gear
Someone else mentioned starting bike like 50 times for 3 minutes at a minimum--might be onto something to clear an old code.....
Blueflame1
May 31, 2013 02:18 AM
cweiss
Aug 21, 2012 03:05 PM
Alter
Jul 3, 2012 10:51 PM
shuggy
Nov 4, 2011 06:39 AM
illmatic96
Jul 6, 2010 10:43 PM
