Replacing rear tail lamp bar questions?
Old Apr 4, 2017 | 02:47 PM
Hesh81's Avatar
Hesh81
Default Replacing rear tail lamp bar questions?
Hey guys, when storing my bike last season, I pushed on the rear tail lamp bar that came factory on my 2006 Road King Classic and broke it. It is the really wide bar.
I have a replacement narrowed bar but wanted to know - can this bar be swapped out with the fender and rear wheel/tire in place or am I in for a big ordeal?
Any tricks or tips you can provide?
Old Apr 4, 2017 | 03:17 PM
grbrown's Avatar
grbrown
If you jack up the rear of your bike, so the rear wheel hangs down, you may get more space to work in around the back of your light bar.
Old Apr 4, 2017 | 04:58 PM
madwrencher's Avatar
madwrencher
I did one on my 2013 i could just reach under the fender. But it has a wider fender and tire than you do.
Old Apr 4, 2017 | 05:09 PM
Cozz's Avatar
Cozz
I just changed mine out recently. It's a bitch, but can be done. Not much room in there. The longer the wrench or ratchet the better. I didn't even think to try my air ratchet, which would have made it easy, if it would fit up in there. Stupid me.
Old Apr 4, 2017 | 06:05 PM
RevBlk's Avatar
RevBlk
On my 07 I used a 1/4 inch drive ratchet with the tire in place and the bike lifted. My bro did his with a box end ratcheting wrench again with the tire in place.
Old Apr 4, 2017 | 06:15 PM
MURPHCC1's Avatar
MURPHCC1
I disconnected upper shocks and dropped the wheel ........gave me some more room to get in there.......
Old Apr 4, 2017 | 07:37 PM
Kburgad's Avatar
Kburgad
On my road glide I removed the large light and circuit board then used a 1/4 inch drive flex head ratchet to remove the 2 mounting bolts for the turn signal bar from the fender.
Old Apr 4, 2017 | 08:51 PM
Jshopes's Avatar
Jshopes
its not bad, i just did mine this fall. It was a pain in the *** while i was trying to figure it out. Take the tail light off, pull the plastic piece out, then work on the 2 nuts that hold the light bar in place. This is way easier than trying to get in from the bottom. The nuts are right there under the big square hole on the inside.
Old Apr 4, 2017 | 09:24 PM
Jshopes's Avatar
Jshopes
Go through the tail light
rebel7
Jun 26, 2018 03:58 PM
SGLarry
Oct 6, 2014 06:01 PM
Erock1800
Mar 6, 2014 12:02 PM
SeniorChief56
Apr 1, 2012 07:04 PM
dslwraith
May 21, 2008 04:18 PM
