Stater Plug
Old Apr 19, 2017 | 09:18 AM
acchd's Avatar
acchd
Check your shift shaft seal too chances are it's leaking and it's common. I just fixed both those leaks this weekend fun project.
Old Apr 19, 2017 | 09:24 AM
jamala00's Avatar
jamala00
Did you do both from the outside? (ie black RTV) I'm guessing not since you did the shift shaft as well.
Old Apr 19, 2017 | 09:37 AM
acchd's Avatar
acchd
I took outer & inner primary covers off. It was good time check the infamous compensator and surprisingly it looked good along with tensioner. Also checked inner primary bearing and replace that seal on inner cover. I got a '09 like you. Friend I know at local HD dealer said about all there trade in's have leaking shift shaft seals and it make service guys happy . My stator just started acting up few weeks ago with leaking. I replaced stator too but have seen guys just remove it and seal it with RTV from inside. With doing that level of work I just replaced stator and called it day.
lmz5150
EVO
May 24, 2018 12:25 AM
REDRUMULTRA
Apr 19, 2013 08:43 AM
gene431
Mar 24, 2013 09:03 PM
FXRCLC
EVO
Sep 29, 2012 08:36 AM
JosephH1
EVO
14
Apr 28, 2011 09:12 AM
