Toby
Old Apr 21, 2017 | 02:46 PM
rlcram's Avatar
rlcram
Stage I
Default Toby
I have an 08 Ultra Classic, and could use an extra 2" in handle bar height. Would this be doable without changing control cables?
Old Apr 21, 2017 | 02:56 PM
dawg's Avatar
dawg
You would want to change out the clutch cable to a 38649-08A cable. Could be done without, but would require reroute. There is enough of the other wires to not have to change. The brake cable can be rerouted inside the fairing to give a little extra room. The Khromewerks 2+2 sweepers are nice and not expensive.
Old Apr 21, 2017 | 03:59 PM
SBates08's Avatar
SBates08
You can go up to 10"s without having to buy cables or wire extensions. Clutch cable will need to be moved around some and hand control harnesses will have to reconnect under the radio instead of their original places in the fairing.
Old Apr 21, 2017 | 06:48 PM
Cosmic Razorback's Avatar
Cosmic Razorback
Community Influencer
Active Streak: 30 Days
Toby?????
Old Apr 22, 2017 | 01:11 AM
From_Behind's Avatar
From_Behind
Originally Posted by Cosmic Razorback
Toby?????
Bamford.
Old Apr 22, 2017 | 03:01 AM
tfi racing's Avatar
tfi racing
Toby?????
I give up? Some kind of goofy,trendy annoying as hell acronym?
Old Apr 22, 2017 | 07:26 AM
Bowhunter61's Avatar
Bowhunter61
This is what I did when I first put my 10" bars on. Then I ended up buying a +4 clutch cable and installed it when I had the new motor put in. I didn't like the location of the cable after rerouting it.
kcollins
Jun 10, 2017 09:55 AM
mkguitar
Jan 2, 2017 06:29 PM
mandd71974
Aug 20, 2016 01:39 PM
oinker02
May 30, 2013 05:51 AM
rhoppe
Sep 13, 2008 10:00 AM
