noise from engine
Old May 1, 2017 | 03:18 PM
pauledangerously's Avatar
pauledangerously
Stage I
Default noise from engine
Have a 2006 Ultra Classic been upgraded to 96 has a loud chain sounding noise coming from right side..figured it was cam chain tensioners..when we got it opened up it had been upgraded to Screaming Eagle Hydraulic cam plate and tensioners..Front side didn't seem loose...could the secondary be my problem?
Old May 1, 2017 | 03:39 PM
Veekness's Avatar
Veekness
Could be that the noise is actually coming from the left side and could be in your primary. Sometimes these noises are deceptive...use the screwdriver method to see if you can't narrow it down a bit...
Old May 1, 2017 | 04:05 PM
2AMGuy's Avatar
2AMGuy
Community Influencer
If you can hear it, you shouldn't be riding it until you're located and /or fixed the issue.
As someone said earlier, its possible that you may be getting an echo from your primary chain but don't assume anything or take any unnecessary changes of damaging your engine.
Old May 1, 2017 | 04:11 PM
Jackie Paper's Avatar
Jackie Paper
The so-called Screaming Eagle Hydraulic cam plate and tensioners upgrade leave the inner chain as is with a link original. Total garbage. Harley screwed people from 1999 till about 2007 and twice for those people who purchased that garbage. Sadly, no one has sued them. They last about 20K and even less if someone modified the oil pressure spring. Peer in there and see if the chain link pins are hitting tensioner shoe.
And welcome from Hampton Roads Virginia. Love your User name. Never met a TN person who did not drive like a mad man.
fastflooge
Jun 28, 2018 06:57 PM
auburn08
Engine Mechanical Topics
Aug 22, 2015 06:49 PM
Sgt York
13
Jun 6, 2015 03:42 PM
cam2zap
Jan 19, 2014 01:28 PM
jbt
Exhaust System Topics
May 16, 2008 11:50 AM
