No start.
Old May 12, 2017 | 02:20 PM
btsom's Avatar
btsom
NOW read the manual and find out to put in your own PIN and over ride the security system, and practice. It is only a matter of time before this bites you again when you are out in the middle of nowhere with no cell coverage for a rescue.
Old May 12, 2017 | 05:02 PM
nutsandbolts5212's Avatar
nutsandbolts5212
Originally Posted by HarleyDoug
Having the same problem. Changed the bars on my 2009 Ultra and now I get nothing when i hit the starter button. i have read this entire thread and done everything including checking for pinched wires on the handlebars and still nothing, I feel as if it is a security system problem. When I turn on the ignition switch, the fuel doesn't prime,the security indicator flashes a couple times and then stays on solid. I have changed the battery in the fob and checked its contacts. The battery is fully charged. I also noted that the siren is not sounding so i changed the 9v battery with a new one. I also checked the harnesses for the new bars. If anyone has any suggestions, I'm all ears. thanks in advance.
Ah, the notorious run/stop switch. Yeah, always keep the switch in the run position, ALWAYS!! My 09 King did it from the very beginning, and continued to do that until a few guys in my club said the same. It now happens once in a great while, even after 2 bar swaps, just turn off console switch for 30 secs, and turn back on. Otherwise go in the switch housing and see what's up if that don't work. LMK if you get it up and running.
Old May 24, 2017 | 11:40 AM
HarleyDoug's Avatar
HarleyDoug
4th Gear
Just for clarification, the security system does disable the fuel pump at least on the 09 ultra.
Old May 26, 2017 | 06:03 AM
danny54's Avatar
danny54
Replace bike battery, They only last about two to three years, Had the same problem, Not enough juice to turn starter.
Old May 26, 2017 | 10:51 AM
skratch's Avatar
skratch
it didn't on my 2007 road king, 2010 road glide, 2012 road glide, or 2013 cvo.
TheTurd
Jun 20, 2024 05:34 PM
Rodney Bogart
Aug 11, 2016 09:06 PM
cunfuzed
Jul 3, 2014 04:33 PM
walker350
May 21, 2014 06:14 PM
dirtyboy
Ironhead
16
Jun 7, 2009 05:45 AM
