Harley LED windshield trim question
Old May 6, 2017 | 10:21 AM
frenchbiker's Avatar
frenchbiker
Default Harley LED windshield trim question
Guys,
I came across this LED windshield trim from Harley and the description says that it fits 2014 and up models. So the question is has anyone been able to install it on a 2013 or older Tri Glide?
https://www.harley-davidson.com/stor...indshield-trim
If it doesn't fit, is there an equivalent from Harley for 2013 and older models?
I know Custom Dynamics carries one but I wanted to know specifically about this one from Harley.
Old May 6, 2017 | 10:25 AM
Hate Work's Avatar
Hate Work
I guess you could start here:
http://www.harley-davidson.com/shop/...ld-accessories
Arlen Ness, JP Cycles, Amazon all have windshield trims for 13 and under.....
Old May 6, 2017 | 11:08 AM
grbrown's Avatar
grbrown
Wink
One of the challenges we owners of older bikes have is to prove that the latest fancy parts can be adapted, even if the MoCo tells us they won't fit! Plenty of us have retrofitted stuff successfully. Will that trim fit your bike? We need a volunteer to try it.......
Old May 6, 2017 | 11:11 AM
frenchbiker
Thanks. I did start here and that's where I found the link to the model I posted but you will notice that most accessories on the HD site are for 2014 and newer models. It doesn't show older accessories anymore, that's why I'm asking.
Old May 6, 2017 | 11:14 AM
frenchbiker
True. I don't know if there's a big difference between the 2013 and the 2014 fairing, besides the vent. If it has the same width and curvature at the top, then I should be able to install this trim.
Maybe someone has done it already, we'll see.
Old May 6, 2017 | 11:42 AM
grbrown's Avatar
grbrown
If you look at older fairing trims (they are on the H-D website) they look the same for your model year as the later ones. I suspect the only reason the lit one is not listed for your model year is that the wiring is not compatible, however I'm sure your bike's can be adapted. You can read the installation instructions on the website, if that helps you decide if it will work.
Old May 7, 2017 | 05:17 PM
Hate Work's Avatar
Hate Work
One way is to load your bike info first, then search, you can narrow down on the left column. An easier way is to google exactly what you are looking for.... Such as, "wigits for 2012 Harley Sportster". I don't have a problem finding anything on the web. I have trouble saying "no, I don't need that!"
Old May 7, 2017 | 05:32 PM
Budda109's Avatar
Budda109
Default Check this one out.
http://www.dragspecialties.com/produ...oductId=410811 This is the one I have. You only have to drill two hole instead of 4 or 5 which CD uses. Mine is a 2011 Electra Glide Ultra Limited. I will see If I can download a pick I have. Turns yellow and blinks with turn signals also. File to big to add sorry.
frenchbiker
May 11, 2017 09:21 PM
SEETHROUGHBRAZ
Vendor For Sale Classifieds
Oct 15, 2014 06:28 PM
SEETHROUGHBRAZ
Aug 18, 2014 09:27 PM
Talldog
Jul 24, 2014 06:40 AM
InMotionJosh
Touring Parts
Jan 27, 2012 08:16 AM
