Do I need a 2nd oil cooler?
The bike has an oil cooler up front. Would it be beneficial to buy and mount a second oil cooler with fan??
Steven
No you don't need it (or a parade fan) unless you spend hours a day idling in Miami....
I have a Lenale fan that I bought after hearing horror stories about main street at Sturgis. After 5 years other than testing I use it once or twice a year and to be honest I have probably never really needed it.
If you want to see a major reduction in heat one of the better designed Fans that flow air across the heads will do a lot more than any oil cooler.
I won't bring up brands because it starts a war. Just a snap shot of what a difference it can make . If you feel it is necessary. This was done on a 2013 103. The bike enjoyed a long life. Same thing with the fan on a 2007, and 2011.
These numbers came from the Dynojet tuner, not a wild guess with a thermal gun.
Out side air was about 70 degrees
103 with lowers open
SYN 20/50 oil
Temp management off
No natural air flow
Started bike allowed to idle
At 261 turned on Fan
40 seconds dropped to 255
90seconds 239
120 seconds 225
at this point the drop slowed a bit
3 minutes 219
5 minutes holding 219 @ same 1000 rpms
7 minutes raised to 221
10 minutes 221 1000 rpms holding
Fan off
10 seconds 230
1 minute 248 climbing steady
1 minute 30 262
2 minutes 266
3 minutes 277
3minutes 20 280
4 minutes 293
FAN on drops of 1 degree per second or so
2 minutes 260
3 minutes 248
4 minutes slowed to 237
FAN off allowed to come to 331
Fan on
Fast drop
1 minute 289
came back down to 228
I live in Houston and commute daily in traffic. I've been stuck in stop and go traffic more times than I can count. Temps in the high 90's. My engine was still running fine when I had it opened up for the first time at 112,000 miles. The only reason I did is because I had the money in the bank and wanted to upgrade it. The indy that rebuilt it said normal wear. Worst being the valve guides. Could have been the heat in the heads but after 112,000 miles, who knows and who cares what caused it. That's a pretty good life for an air cooled motor and it could have kept going a lot longer.
If you are worried about the heat, find ways to make yourself cooler or the heat you feel more tolerable before worrying too much about the engine.
Just an opinion that doesn't mean anything from a guy that rides in the heat every day. I'm sure others will tell you the fans are a must. Fans or an better oil cooler can't hurt but your question was, do you need another cooler. My answer would be no, what you have works fine.
I have an oil bud cooler and it drops the temp 35 degrees but the rear cylinder still almost burns my right calve on my leg at times.
Anything that prevents the heat from escaping is merely holding it in IMO regardless of what you are using.
I don't have the fans either so I do not have an opinion on that.
Jason of Wardwerks said that he did not know if I purchased his fans if that would fix my heat issue either so I didn't buy his fans.
https://www.hdforums.com/forum/touri...e-in-fl-2.html
at idle, without adjusting oil pressure for 2nd cooler, its a concern. i think changing the spring in tge oil pump to a baisly spring could readily overcome this issue.
i have seen 2 twin cams both a 95 and a 103 with twin jagg 10 rows. neither rider expressed any other concerns except idle oil pressure
both engines consistently ran temps below 220. this was in Alabama where heat and humidity are present
