01 electreglide,rear brakes
Old May 22, 2017 | 05:52 PM
joe cosstello's Avatar
joe cosstello
Stage I
Default 01 electreglide,rear brakes
do I have to remove the rear tire to change the brake pads
Old May 22, 2017 | 07:00 PM
dawg's Avatar
dawg
It can be done without removing the rear wheel.
Old May 23, 2017 | 07:20 AM
Harley58's Avatar
Harley58
Exactly what Dawg said.
Old May 23, 2017 | 12:53 PM
Guntoter's Avatar
Guntoter
I use a putty scraper to get between the pads and rotor to carefully pry the pads back, then remove the 2 pins and you can rotate the pads out. Reinstall the same, you can slide each pad in at a time, make sure you put some of the anti-squeal grease on the back of the new pads first.
All Aces
May 21, 2017 08:29 AM
ms3300
Jul 26, 2010 04:07 PM
rickshog1
Oct 20, 2008 07:35 AM
jokr
Feb 3, 2008 06:10 PM
Hdbiker1450
Oct 13, 2006 08:55 PM
