Can't squeeze front brake handle
Old Aug 14, 2019 | 12:17 PM
jake2351's Avatar
jake2351
oops! i didnt look at the date. im such a bozo sometimes.
Old Aug 14, 2019 | 12:41 PM
TriGeezer's Avatar
TriGeezer
Originally Posted by J_MOSH
Jake..... I'm gonna a guess the op's problem was solved 2 years ago.
Old Aug 14, 2019 | 08:58 PM
Zonktified's Avatar
Zonktified
No worries man...it is funny about the date but nice of you to post such a thorough response in order to help a brother out! 👍
Old May 29, 2020 | 01:06 AM
moosebop's Avatar
moosebop
Stage III
Default Thanks Jake
I am having the exact same issue. I just purchased an 06 Dyna Street Bob with 231 miles on it. The bike has basically been sitting it’s whole life and she’s a little rusty. Front brake lever won’t compress at all, unless you loosen the banjo bolt. Tried bleeding, but nothing would come out and lever would not compress. I’m going to follow Your advice and see where it takes me. No abs so shouldn’t be too difficult. I’ll keep you updated.
Old May 29, 2020 | 06:46 AM
BelchFire's Avatar
BelchFire
Brake fluid is hygrosopic, so if your bike has been sitting, it has collected moisture and likely corroded the lines, resulting in a completely plugged/clogged line. From your description of having tried bleeding with no results, you're going to be up for replacing the line at a minimum and likely a rebuild or replacement on the caliper as well.
Old May 29, 2020 | 11:06 AM
moosebop's Avatar
moosebop
Stage III
thank you for the heads up. I did not consider that. I appreciate all the guidance I can get.
Old May 29, 2020 | 01:04 PM
BelchFire's Avatar
BelchFire
Glad to chime in. I hope I'm right and I hope you get it going again soon. Brakes are important. If this is not something you've done before you might want to consider taking it to a shop (HD, or indy isn't as important), just to make sure your brakes are correct. If it's corrosion, the master cylinder may need attention too. Don't cheap out on brakes.
Old Jul 5, 2020 | 03:32 PM
gvoxx's Avatar
gvoxx
Just a heads up for those of you that have ABS, you can now bleed and cycle your ABS system yourself. The tool is $179 at infotechmercenary.com. He sends you a 7" Acer tablet with a module you plug into your bikes data port. The tablet connect via blue tooth and will activate your ABS just like the Harley dealers digital technician. This tool pays for itself in one use.
Johnniev
May 22, 2017 10:29 PM
Mel A
Oct 28, 2014 01:16 AM
JMAY_ATL
Ironhead
Sep 29, 2014 06:09 AM
HamToast
Feb 23, 2013 05:37 PM
frogg
May 31, 2009 01:30 AM
