Clutch Issue?
Old Jun 11, 2017 | 11:13 AM
FastHoss's Avatar
FastHoss
Default Clutch Issue?
2013 Ultra , 70,000 miles clutch works perfect but after lubing the cable and adjusting the clutch the pull is light and easy. After a day or so the clutch still works fine but it is harder to pull in. I have adjusted it twice now what do you think?
Old Jun 11, 2017 | 11:34 AM
Veekness's Avatar
Veekness
I'm thinkin' you might be in the market for a new cable...might be some fraying of the cable inside the housing that frees up a little with some lube...then the lube moves on as per the law of gravity...and if that's the case, one of these days when you're out and about, the cable is gonna snap, and that will complicate the day's ride a bit.
I personally like Barnett cables, but there are a number of fine aftermarket ones out there...or OEM...
I will make this disclaimer that most all problems are difficult, many times impossible, to diagnose from the World Wide Web...but that's the sense I have based on your description...
Old Jun 11, 2017 | 12:03 PM
grbrown's Avatar
grbrown
Wink
Fit a new clutch cable, yours may well be worn out of sight inside the outer. I swapped to a Diamondback at a lower mileage and was amazed how much smoother and lighter it is.
thanoskazakos
Aug 11, 2018 08:48 AM
rdondes
Oct 23, 2013 08:16 PM
ronyd
Mar 19, 2008 10:39 AM
rkcrwlr
Mar 6, 2008 03:44 PM
bubba_d_duck
Jan 27, 2007 09:35 PM
