heel/toe shifter
Old Jun 20, 2017 | 09:27 PM
Roger86's Avatar
Roger86
4th Gear
Default heel/toe shifter
does riding with my foot on the heel shifter on harley davidson hurt anything in the tranny
Old Jun 20, 2017 | 09:28 PM
Iceman24's Avatar
Iceman24
Hit a big bump & you'll quickly find out.
Old Jun 20, 2017 | 09:29 PM
Honey-Badger's Avatar
Honey-Badger
Old Jun 20, 2017 | 11:02 PM
groupw's Avatar
groupw
... heck, hit a small bump & see what happens
Old Jun 20, 2017 | 11:19 PM
TriGeezer's Avatar
TriGeezer
It'll just upshift...
OP: Don't do that....you'll be cutting constant pressure on the shifter forks...and that can't be good. Take it off invites in the way.
Old Jun 20, 2017 | 11:22 PM
Ceez's Avatar
Ceez
This seems like a thinly veiled troll attempt..
Old Jun 21, 2017 | 04:10 AM
Bluehighways's Avatar
Bluehighways
You do not want to keep a constant pressure on the shift linkage. Doing so, will result in extremely rapid wear on the gear shift mechanisms within the transmission.
I happen to like having a heal shifter. I use it for finding neutral with just a lite tap from my heal. It's about the only thing I use it for, but for that purpose it's really nice to have. The challenge for me is/was that my size 13's will not fit comfortably between the stock toe and heal shift levers. So what I did was to replace the stock heal shift lever with a V-Factor Chrome Extended Shifter Lever P/N 44217. At 8 1/2" It looks and works exactly like the stock lever, only it's quite a bit longer. The pinch bolt is slightly smaller in diameter than what the stock shift lever uses, but you'll have to be pretty **** to notice that. DennisKirk has it for ~$21.00 and there are probably other folks who sell it.
https://www.denniskirk.com/v-factor/...prd/579080.sku
Old Jun 21, 2017 | 05:02 AM
grbrown's Avatar
grbrown
Now why would you want to do that? I don't use my heel shifter, except it stops my foot sliding backwards on the floor board, so the rubber is worn, but I don't deliberately touch it or rest my foot on it.
Old Jun 21, 2017 | 05:31 AM
HKMark23's Avatar
HKMark23
Originally Posted by Bluehighways
You do not want to keep a constant pressure on the shift linkage. Doing so, will result in extremely rapid wear on the gear shift mechanisms within the transmission.,,,,,,,,,,
"Coincidentally",, I was at my Indy's a month or so ago having tires installed. When I went to pick up my bike, because he had noticed the H/T shifter on my Breakout, my Indie showed me a transmission he had apart and was working on at that time. "He was warning me never to ride the heel shifter"
Technical terminology escapes me so please be patient.
There is a fork shaped thingy which fits into a circumferential groove machined into the outer surface of a cylindrical part, (selector ??), that is moved back and forth along a shaft as dictated by the fork when you shift. This groove will wear prematurely making shifting sloppy or worse in time if you ride the heel shifter. My Indy was able to show me the actual groove wear in the transmission he had torn down specifically because of this,,, "expen$ive" !!
Apparently this sort of wear was common in old standard transmission 1/2 ton trucks with a floor shift. This was due to drivers resting their right hand on the shift **** as they drove. Apparently this caused the same type of wear as now seen in motorcycle transmissions when riders rest their heel on their shifters.
FWIW
Old Jun 21, 2017 | 05:36 AM
HKMark23's Avatar
HKMark23
Per my post above, apparently the heel shifter / heel contact is more or less an unconscious thing with some riders and not that they're using the shifter as a heel rest. Apparently it doesn't take much for this unintentional contact to do the damage. This is why my Indie was warning me.
