Air Horn
Old Jun 25, 2017 | 04:25 PM
PDawgWms's Avatar
PDawgWms
Stage II
Default Air Horn
Does anyone know of a direct replacement air horn for a HD Street Glide? I want to replace my stock horn, but I want to avoid the wiring harness. I hope I can get a replacement horn that uses the existing HD horn connections.
Old Jun 25, 2017 | 05:16 PM
mkguitar's Avatar
mkguitar
you will WANT to wire in a relay for an air horn- they pull more power than the stock wiring can carry with out damage
I'd stay away from howards horns- mine failed pretty quick.
I have an HD air horn which is been great- and came with a relay...pricey - I bought mine used.
the stebel nautilus is also a popular horn for bikes
Mike
Old Jun 25, 2017 | 05:58 PM
OkieBill's Avatar
OkieBill
+1 on the relay. Quick tip you may want to add to your installation is secure the relay to the socket with a small zip-tie. The first time I needed my Wolo air horn when a cage pulled right in front of me I hit the button and got...nothing! Oops! My error but was able to avoid anything that day.
Zip-tied really into socket.
Unsecured relay.
Old Jun 25, 2017 | 06:01 PM
Markymannn's Avatar
Markymannn
Direct plug-in. Much better than stock. It is what I bought when my oem failed
http://www.jpcycles.com/product/902-...FcpLDQodPZ8D8g
Old Jun 25, 2017 | 07:35 PM
Veekness's Avatar
Veekness
I installed a Bad Boy horn on my 2006 Street Glide directly into the existing wires...never a problem and they were as loud as they should have been. That said, Mike is correct...most situations require a relay, and its not that big a deal.
​​​​​​​On my current 2011 Glide, I just installed the loud horn out of the P&A catalog. Works fine.
Old Jun 26, 2017 | 05:40 AM
mastergunnera8's Avatar
mastergunnera8
I put these on mine, on stock mounting point, opposing, simple wiring in parallel, loud
Amazon Amazon
Old Jun 26, 2017 | 05:59 AM
str8shuutr45's Avatar
str8shuutr45
I installed a mini-beast air horn to my 13 RK - it was plug and play
Old Jun 26, 2017 | 10:27 AM
Pumba11's Avatar
Pumba11
Mike
Interesting, my Howards Horns are over 10 years old and going strong. Just my experience.
Old Jul 20, 2018 | 08:39 PM
Jonny Rotten's Avatar
Jonny Rotten
I put a Wolo on my other bike. Sounds like a truck horn, I little to much for me but gets their attention
Old Jul 21, 2018 | 08:04 AM
Spartanden's Avatar
Spartanden
custom dynamics mini-beast is bolt on plug and play... a bit expensive, but I love it!!
Nellybelle
Electrical/Lighting/Alarm
Sep 21, 2014 06:24 PM
chgofirefighter
Mar 11, 2014 09:14 AM
Figstr
Mar 3, 2012 12:03 PM
artist123
Product Reviews
Sep 14, 2010 01:30 PM
tatersalad
Product Reviews
Nov 29, 2007 04:33 PM
