No Sound
Old Jul 3, 2017 | 07:16 AM
kimm52479's Avatar
kimm52479
Stage III
Default No Sound
Good morning all,
I'm writing on behalf of my husband, who is beyond sick with this bike at this point.
It started with needing to replace the inner fairing on his 2010 Electra Glide Ultra Classic. He's owned and worked on upwards of 40+ bikes in the time that I've known him, so he's very well-versed on how to do basic maintenance and repairs. Please note that all electrical and sound components were working fine before all of this.
He disassembled the wiring, meticulously tagging each and every wire so that it could go back just as he found it... something he's done plenty of times in the past. Currently, he's running the stock head unit with a Biketronics 4180 amp and Titan speakers. All of the wiring went back pretty effortlessly without any hitches, until he went to check all of the components.
First, the display on the head unit wouldn't come on. After checking the fuses, he discovered a bad one, changed it out and the display came back on. However, there continues to be no sound... at all. He did a reset on the head unit, but that didn't work. He's checked and re-checked all of the wiring and everything is where it should be and tight.
He's pretty much at a loss and we're reaching out to the forum to see if anyone might offer a suggestion of something he maybe hasn't tried.
Your community expertise is greatly appreciated and I'm hoping with your help we might just find the solution.
Thank you all in advance,
Kim
Old Jul 3, 2017 | 07:55 AM
big- mike's Avatar
big- mike
I have the same bike a few years ago I trailered it to sturgis my radio was fine for 5 minutes out of the trailer then quit when I got home I sent it to iron cross audio to be checked and low and behold believe it or not over time it became damaged by the bolts that hold the handle bas down they were hitting the bottom of the radio ( the heads of the bolts were too big) iron cross updated the unit and sent me a copy of the bulletin from Harley that included the part numbers of the new bolts.
Old Jul 3, 2017 | 10:15 AM
skratch's Avatar
skratch
is there a fuse on the amp's power wire? also, I would try running a line in to the rca plugs on the amp, using the headphone jack on my iPhone, basically eliminating the stock hu from the equation. if you get sound then, you know it is something in the hu. if you don't get sound, then you can focus your troubleshooting on the amp.
Old Jul 3, 2017 | 10:20 AM
hdbob2006's Avatar
hdbob2006
My amp has a separate inline fuse near the battery-
Old Jul 3, 2017 | 10:26 AM
dgoodbmw's Avatar
dgoodbmw
Default try this
There is a speaker switch on ign panel, maybe it got flipped in error.
Old Jul 3, 2017 | 11:30 AM
sr230mike's Avatar
sr230mike
My 08 has a speaker switch on the dash . Make sure it is in the correct position.
Old Jul 3, 2017 | 11:39 AM
kimm52479's Avatar
kimm52479
Stage III
Default Update
Update: he just ran the head unit directly to the speakers. That works. The the issue is with the amp. Calling Biketronics and hopefully they'll honor the lifetime warranty.
Old Jul 6, 2017 | 01:31 PM
CalgaryBikeBum's Avatar
CalgaryBikeBum
Perhaps the signal wire that tells amp to startup was not connected? It's blue I beiieve. Usually you can hear the fan on the biketronic unit.
Old Jul 6, 2017 | 03:22 PM
kimm52479's Avatar
kimm52479
Stage III
You're pretty much on the nose. We worked with Mike at Biketronics and he was very helpful. We got it all fixed!
grampaG
Audio Systems
Jun 14, 2019 06:58 AM
WestTexasRanger
Audio Systems
Feb 7, 2016 04:33 PM
margin5
Audio Systems
Aug 10, 2015 07:52 AM
HD_Doobie
Audio Systems
Jul 21, 2014 09:35 PM
speedracerx0509
Audio Systems
15
Sep 27, 2013 12:15 PM
