Went on a nice country road ride today on my 2010 ultra and I noticed rolling through the curvy part of the road I could feel a funny slight vibration in the bars didn't matter if I was sweeping right or left it was there then after the curve going straight it went away tires are mc2's with about 3000 miles on them it wasn't bad but I did notice it. I'm thinking possible wheel bearings. Any other ideas?
Do you have a lift? Get the front wheel off the ground and give it a spin. See if it is smooth or if there is grinding. Look for play right and left, do a visual inspection of the bearings. You should be able to tell pretty easy. Don't take a chance until you know for sure.
Yes, do get the bike on a lift and check the bearings. I have those same tires on my bike with about the same mileage. This is what I have noticed in the turns. The tires make a different noise when rolling on the side as opposed to rolling down the middle of the tread. I haven't noticed a vibration but there definitely is a different sound. Hope this helps.
Pry the calipers off center slightly to push the brake pads in. It will allow the wheel to spin free. You may have to loosen the caliper bolts which takes a special socket. I'll bet it's tire noise.
I'm not saying it's not a bearing issue, buuuuut It appears some duel compound tires are showing tread side wall cupping (see post #6 in link below).
2012 FLHR (Road King) Ember Red Sunglo & Merlo Cruise Control, ABS, Chrome Aluminum Profile Laced Spoke Tubeless Wheels, Security Package, Saddle Bag LED Lid Spoilers, and an array of accessories that enhances nostalgic appearance & blood curdling performance.
Great spirits have always encountered violent oppositions from mediocre minds.
