1996 Electra glideaxle size
Old Jul 8, 2017 | 05:18 PM
HD725's Avatar
HD725
2nd Gear
Default 1996 Electra glideaxle size
Is there some sort of chart or page with axle sizes. I wanna change my front wheel but the axle sizes seem to be all over the place?
Old Jul 8, 2017 | 05:52 PM
FreedomRider's Avatar
FreedomRider
Axle diameter for the '96 Electra Glide is .75 (3/4 inch)
Old Jul 8, 2017 | 08:12 PM
HD725's Avatar
HD725
2nd Gear
Greatly appreciated!
Old Jul 8, 2017 | 10:25 PM
mkguitar's Avatar
mkguitar
later 1" axle wheels can be used- you just use the 3/4" i.d. bearings
that expands your options
or you can change the lower legs if you what to move up from the single piston brake calipers- later brakes are quite a bit better.
and those lower legs will likely use a 1" axle
mike
Old Jul 8, 2017 | 10:59 PM
Veekness's Avatar
Veekness
I seem to recall that somebody on this forum put together a chart on axle and bearing sizes a while back. Might be something worth researching.
Old Jul 9, 2017 | 09:27 AM
rizzo's Avatar
rizzo
You're options are endless. I have a late model wheel on my 3/4" axle. You're really only limited by the ingenuity of the folks putting on the wheels.
https://www.hdforums.com/forum/evo-c...-3-4-axle.html
Joe Dirt 14
Jan 23, 2016 08:46 PM
Jerm83
May 24, 2013 04:28 AM
camshaks
Apr 9, 2011 07:55 AM
j1mmy
Classic
Feb 27, 2011 09:27 AM
LouEyez
May 5, 2010 06:07 AM
