Clutch question
Old Jun 8, 2007 | 11:07 PM
eglidebob's Avatar
eglidebob
Default Clutch question
My 05 Standard seems to "clunk" when downshifting, especially from 2nd to first gears. Is this a clutch adjustment or clutch cable adjustment? I have a manual so can do the work myself. Thanks in advance.
Old Jun 8, 2007 | 11:17 PM
nb472's Avatar
nb472
Default RE: Clutch question
Sounds like a Harley to me. You could check the clutch adjustment as described in your manuel or there is a good link in the DYI section on clutch adjustment the easy way. I switched to Redline Shockproof heavy in the tranny, and it helped a bunch.
Old Jun 8, 2007 | 11:20 PM
old.gezr's Avatar
old.gezr
I run Redline severe Gear synthetic in my 07 SG and it reduced the ckunkquite a bit. I think the rest of the clunk is just "Harley" speak.
Old Jun 8, 2007 | 11:27 PM
Timex's Avatar
Timex
A Quality Synthetic will be smoother ...
Old Jun 9, 2007 | 11:30 AM
eglidebob's Avatar
eglidebob
I failed to mention, I am using Redline HSP. Thanks.
Old Jun 9, 2007 | 05:54 PM
Timex's Avatar
Timex
Filled to proper level?
Old Jun 9, 2007 | 09:56 PM
Lil Truckr's Avatar
Lil Truckr
That 'clunk' might just be coming from your primary chain also...
Check to see that its properly adjusted. My '02 Ultra 'clunked' all the time when I shifted until I installed a hydraulic chain tensioner. Once it was installed, no more 'clunk'...
Just a thought...[&:]
[IMG]local://upfiles/21506/340392FEF70D4826862D59898BCD7925.jpg[/IMG]
Old Jun 9, 2007 | 10:26 PM
Peekaboo Bob's Avatar
Peekaboo Bob
Raise your RPM's while the clutch is pulled in to match your tranny speed to your engine speed and it will be smoother.
Mdbell714
Jan 22, 2016 08:48 AM
MURPHCC1
Sep 4, 2015 09:34 AM
Kebo
Jun 22, 2013 07:29 PM
mrthinkshesfunny
Jan 18, 2010 02:11 AM
wolf1477
Ironhead
Jan 16, 2007 04:23 AM
