1995 electra glide ultra
Old Jul 10, 2017 | 05:26 PM
oldglide95's Avatar
oldglide95
3rd Gear
Default 1995 electra glide ultra
Intermittantly the radio cuts out when braking or turning on the turn signals, I also have a 95 tour glide ultra with the same issue. did anyone else have this issue ?
Old Jul 10, 2017 | 06:14 PM
kempomark's Avatar
kempomark
I do know that my 95 EGC had charging/electrical issues. It had a two phase alternator that complained when too much load was put on it. I finally spent big bucks and went to a three phase alternator and voltage regulator. Problem solved.
Old Jul 10, 2017 | 09:23 PM
mkguitar's Avatar
mkguitar
never saw that on my 95...ran it up over 88,000
mike
Old Jul 11, 2017 | 04:56 AM
grbrown's Avatar
grbrown
Cool
That suggests an electrical fault that involves your brake switches or wiring. You could experiment by disconnecting your brake switch wiring, one at a time, to see if the problem goes away. Have you worked on the bike recently, such as installed new bars, removed the handlebar switches for any reason?
Old Jul 15, 2017 | 01:28 PM
oldglide95's Avatar
oldglide95
3rd Gear
just bought the bike about 2 months ago, the 95 electraglide. the 95 tourglide I have had for 7 years. Both have the same issue. It is only intermitant so It is hard to find dealer said most likely wiring issue.
Old Jul 15, 2017 | 03:42 PM
grbrown's Avatar
grbrown
Red face
It's unlikely to be exactly the same cause on both bikes, you're dealing with a coincidence IMHO. Concentrate on sorting out one bike, then see if that helps you sort the other one.
I had a bike many years ago on which the engine would cut out sometimes when turning on the flashers while riding. It took an electrics expert friend of mine several hours to find the problem, as when stationary the defective connector gave almost normal readings. Dead easy to sort out once found!
So let's take another look at this! Find yourself a quiet road where you can make a few tests, without risk of getting mown down by other traffic. You only have two brake light switches and two sets of direction lights. So with your radio on try just one brake at a time, without operating the other brake, to see what happens. Then while not braking, try one indicator at a time. Note which, if any, of those four cuts the radio. Let us know what you find!
hutchjh828
Engine Mechanical Topics
Jan 26, 2013 08:38 PM
bxhammer
Oct 8, 2012 12:25 PM
sledderjw
May 22, 2011 07:33 PM
tom lipke
Jul 13, 2009 09:50 AM
SoCal_Pappy
Oct 21, 2007 09:25 PM
