Hottest plugs?
Old Jul 24, 2017 | 07:52 PM
Joseph Holland's Avatar
Joseph Holland
2nd Gear
Default Hottest plugs?
I have a 2017 Ultra Limited with the Milwaukee 8, Rinehart slip-ons, and a stage I air cleaner. What brand and the hottest plugs can I use?
Old Jul 24, 2017 | 08:19 PM
Longridertx's Avatar
Longridertx
What's wrong with just using the stock plugs? Stock plugs are pretty much all you need. I run stock plugs in my modded 15 Ultra and have no issues.
Old Jul 24, 2017 | 08:23 PM
bigskyroadglide's Avatar
bigskyroadglide
what he said. stock plugs work in 99.99% of all applications.
Old Jul 24, 2017 | 08:27 PM
Veekness's Avatar
Veekness
OP, why do you think you need hot plugs? You might want to do a little research on plug heat ranges.
Old Jul 24, 2017 | 08:37 PM
cdonis's Avatar
cdonis
Do yourself a favor. Stock plugs and wires.
Old Jul 24, 2017 | 08:44 PM
Veekness's Avatar
Veekness
​​​​​​​Yessir! Outstanding advice!
Old Jul 24, 2017 | 08:54 PM
Joseph Holland
2nd Gear
OK NGK plugs it is. Thanks guys.
Old Jul 24, 2017 | 10:10 PM
rgrecco's Avatar
rgrecco
I'm running NGK Irodium in my '10 Ultra Limited.
After I bought the bike 2 weeks ago (22000 miles) I did an overhaul... Oil (Mobile1 VTwin), K&N Oil Filter, K&N Air Filter (Stage1), Plugs, Exhaust (Rinehart 4" Classic Duels), and DynoJet PC V
Old Jul 24, 2017 | 11:11 PM
Veekness's Avatar
Veekness
I believe there's some confusion regarding 'hottest' or 'hot' plugs. Generally, those terms refer to the 'reach' of the plug's nose. When you're having burn problems, for instance, if a plug is getting fouled by oil, you use what has become to be known as a 'hotter' plug...one with a longer nose or reach. Other knowledgeable guys feel free to chime in to elaborate or correct me, but a 'hotter' plug, in the main, isn't referring to a higher performance spark plug.
The term 'overhaul' generally refers to the rebuilding of an engine, ship, what have you, when it has become worn out and needs to be brought back to as-new...or better...condition. I've never known it to be used when describing routine maintenance or adding equipment to a vehicle.
Old Jul 24, 2017 | 11:22 PM
0ldhippie's Avatar
0ldhippie
Most higher compression performance engines actually require cooler plugs not hotter ones...and higher octane fuel burns slower, not faster...
