Hotter than standard plugs were OK back in the carb days when it was running rich, but I'd stick with stock.
Hotter plugs weren't really for when it was running rich, but carbon tracking. Some used them for the hard to "tune" butterfly carbs, but they were mainly just looking for a more complete burn. I've used a step hotter for that purpose and a step colder if she pings, but only on a carbed bike.
How hot a plug is would be determined by how much of the insulator is exposed. It's the plugs ability to shed the heart of combusting combustion. Too cold, it won't be able to burn off excess carbon, too hot, you'll get spark knock or pinching.
Hotter or colder plugs not needed on FI bikes because of knock sensors, injector timing and other various sensors bound and determined to make your bike run smoothly.
Let's not try to out engineer the engineers.
Run your plugs about 10,000 miles, pull 'em, look 'em over, and then lets continue this discussion.
There's plenty of other things to be concerned with. Run 'em!!
As oldhippie said: Most higher compression performance engines actually require cooler plugs not hotter ones...and higher octane fuel burns slower, not faster...
Buuuuut they already knew that! Right?
B Bop
2012 FLHR (Road King) Ember Red Sunglo & Merlo Cruise Control, ABS, Chrome Aluminum Profile Laced Spoke Tubeless Wheels, Security Package, Saddle Bag LED Lid Spoilers, and an array of accessories that enhances nostalgic appearance & blood curdling performance.
Life isn't about waiting for the storm to pass, it's about learning to ride in the rain. WDB
I have tried them all, Bosch are the best. And yes, cross the same OEM # over. Using hotter plugs is for Shovels and Pans. Also with F I System, there is not the same issues as with the carburetor bikes... https://www.boschautoparts.com/en/auto/spark-plugs
