2007 road king hot start
Old Jul 28, 2017 | 08:58 PM
funguy365's Avatar
funguy365
Stage I
Default 2007 road king hot start
the bike starts great when its cold but if i take it for a ride and the bike gets hot it makes a clunking noise
what is the problem and fix for this
Old Jul 29, 2017 | 10:39 AM
BeSharp's Avatar
BeSharp
Sounds like the compensator to me. You can buy the Screaming Eagle one that's supposed to fix it or the Baker Compensator. On my '09 I can make it happen less often and with less force by waiting longer to start the bike after turning on the ignition and the start switch. I'll replace my compensator next time I have to have the bike open for some other reason.
Old Jul 29, 2017 | 11:58 AM
longrideshields-2's Avatar
longrideshields-2
Premium Sponsor
You can also do a lot test on your Battery. Check all you grounds to you battery, frame to battery and and starter cables, without a full 12.6 volts, being the piston rings have expanded, it takes more juice to start the motor. The clunk may be the motor trying to turn over, until your lag in voltage catches up. Worth 15 minutes of your time....
__________________
LONG RIDE SHIELDS
www.longrideshields.com
Old Jul 30, 2017 | 08:46 AM
DaleMc0622's Avatar
DaleMc0622
Battery is the first thing to check, I had the same issue with my 07 FXD, turned out to be the compensator.
Huckster
Apr 7, 2017 12:04 PM
Southbound71
Electrical/Lighting/Alarm
Sep 2, 2014 11:16 PM
Buddyruff
EVO
Oct 24, 2012 07:03 PM
born4bikn
Feb 2, 2011 01:48 PM
Lozo
Engine Mechanical Topics
Oct 8, 2009 12:24 PM
