reinserting passenger floorboard rubber inserts - problem
Old Aug 5, 2017 | 08:31 AM
Toypuller's Avatar
Toypuller
Soak the rubber inserts in really hot water for 10 minutes.
Push them into the holes and pull them through-gently- with a pair of slotted pliers with rubber or surgical tubing over the jaws.
Spray windex on the holes as you work them through.
Old Aug 5, 2017 | 08:38 AM
Uncle Larry's Avatar
Uncle Larry
The problem with "re-inserting" is that as major105bc pointed out, the original floor board rubbers had a long piece of rubber attached to them that was a provision for pulling through the hole. Once the "flared" piece was through the hole the excess ( long piece ) will break off.
Old Aug 5, 2017 | 08:40 AM
From_Behind's Avatar
From_Behind
This is one of those things that I paid the shop $20 to do and saved my sanity. I couldn't even finish my coffee, and he was done.
Old Aug 5, 2017 | 01:12 PM
skratch's Avatar
skratch
Per the Op's original posting ... "tried looping dental floss around to pull through the hole" :>)
doh! guess I should review the op if it's been a while since I first read it before I go posting a solution.....
hey, maybe you could try some dental floss.......
Old Aug 5, 2017 | 10:02 PM
DBlass's Avatar
DBlass
I installed mine originally on my 09 RK and then moved them over to my 17 RK. No issues. Lube them with detergent or WD40. I used needle nose pliers to pull them through. Did you drill the hole wide enough?
Old Aug 14, 2017 | 06:12 PM
F150HD's Avatar
F150HD
Originally Posted by skratch
could try wrapping some dental floss around the rubber and feed that through the hole and pull on the floss...
per post 1, the floss actually ripped one of the heads off.
Old Aug 14, 2017 | 06:16 PM
F150HD's Avatar
F150HD
there are no holes to drill, the holes come in the floorboards from the factory.
Old Aug 15, 2017 | 04:02 PM
DBlass's Avatar
DBlass
Brain fart.
I had to drill to get the chrome cover to attach to the base. The rubber foot pad just worked. Lube and needle nose pliers. Works here and in other places.
Old Aug 15, 2017 | 04:31 PM
angel suarez's Avatar
angel suarez
3rd Gear
Needle nose pliers worked even without the lube for me. I just completed this about a week ago. Good Luck. The more its stretched, the easier it will make it through the hole.
Old Aug 15, 2017 | 04:32 PM
aviaator's Avatar
aviaator
Originally Posted by 2AMGuy
Using Dawn dishwashing liquid on the rubber "nubs" can help and I've also used small, flat blade screwdrivers to "assist" getting the "nubs" through the holes far enough to "pinch" them and pull hem through the holes using flat-nosed, needle-nose pliers.
Just don't pull on them too hard as they can break or pull apart.
The floorboard metal is kind of delicate so it's important to use short metal screws and just enough torque to "snug" the screws.
^^^^ This.
