Passenger intercom part numbers needed
Old Aug 15, 2017 | 08:42 PM
ictghost's Avatar
ictghost
Default Passenger intercom part numbers needed
I searched parts fiche, the forum and google and couldn't find any answers. I have a 2012 Ultra limited, with Boom! audio (if it matters). I'm wanting the part number(s) for the spring (and black tube that covers the spring) that attaches to the passenger intercom connector. It is located under the left side of the tour pak and runs from the left upper license plate frame, to the intercom cable.
Old Aug 16, 2017 | 06:59 AM
1340hog's Avatar
1340hog
In 2008 the part numbers are 76247-98(spring assembly,retract,w/#10065)The part #10065 are the 4 cable straps to hold every thing in place.It appears that the black tube comes with the spring kit.these numbers i'm sure have not changed.you could call a dealer and give them this number and see if its the same.
Old Aug 16, 2017 | 01:45 PM
ictghost's Avatar
ictghost
Thanks 1340hog...got it ordered today!
Old Aug 16, 2017 | 05:03 PM
IKnowNot's Avatar
IKnowNot
This may come a little late, but figured I would complete the information.
You said you have a Boom Amp installed under the Tour-Pak.
Per the installation instructions, when the amp was installed the spring is supposed to be disconnected from it’s original location on the license plate frame and moved to the lower left slot on the license plate bracket, held in place with a cable strap.
“If stronger headset receptacle retention is desired, the existing spring assembly can be replaced with new spring assembly 76300-06 (purchased separately).”
Old Aug 16, 2017 | 07:51 PM
ictghost's Avatar
ictghost
Thanks for the info. It is currently attached to the lower left slot on the license plate bracket, I just need to replace it. The spring is very rusty and the plastic sheath is split about half way...not really sure what happened there, but I'm just going to replace it. At least it's cheap!
Nitrochicken
Dyna Parts
Aug 2, 2018 08:17 PM
apblingAEW
Jul 1, 2016 04:15 PM
rkoivisto
Mar 30, 2013 06:26 PM
UltraDune
Dec 27, 2010 10:46 AM
Ridin'withTheKing
Jan 24, 2010 02:52 PM
