ABS Mistake
Old Aug 29, 2017 | 08:08 PM
KumaRide's Avatar
KumaRide
Check codes. Maybe ohm it out as one wire would be a ground and easy to verify. To get a reading on the actual sensor, wheels moving and sensor reading bearings, more difficult and may require engine turning wheel to check is a small pulse voltage is created. Dont know for sure, never tried it. $70 for a harness, I'd try to fix as wires are easy to fix.
This may help:
https://www.hdforums.com/forum/touri...ying-on-2.html
Old Aug 29, 2017 | 08:43 PM
Veekness's Avatar
Veekness
Originally Posted by harkon
If you only crushed the wire, my guess is that it can be repaired. It's a pretty fine wire from outward appearances, but if it were me, I'd try a repair. If you have some electronics experience, if you screw it up, worst case it won't work and you are out nothing but some time. If it works, make sure you use some sealing heat shrink to cover up the repair. Slide a length of that on before you solder things up.
If you succeed, it will work as normal, if you fail, you will get a light. Then you know it needs replacing.
Don't forget to disconnect the battery everytime you do a repair like this.
​​​​​​​The sensor unplugs easily, so you can unplug it and do your repair without having to disconnect the battery. The plug should be a little above the lower triple tree, or behind the skirt if you have a faired model.
Old Aug 29, 2017 | 08:55 PM
skratch's Avatar
skratch
Originally Posted by 1957buick
Buy the sensor , you do not want it to start activating the brake while riding !
that's not how it works....
Old Aug 30, 2017 | 08:36 AM
Brewmany's Avatar
Brewmany
I'd just put on a new sensor. Might also want to see what if any, error codes you might be throwing. I doubt anyone would repair the sensor, and if they did it's likely the labor cost would exceed the cost of a new part. So doubt there are any sources of how you might repair this.
Old Aug 30, 2017 | 09:08 AM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
If the copper wires themselves aren't really damaged, just the insulation crushed/perforated, you could just reseal the wire with liquid electrical tape.
If the wire strands were torn apart, then you should be able to make a good repair. I'd solder it myself, as crimp connectors could cause a resistance problem. Then shrink tubing or liquid electrical tape.
Either way, the damage should be quite repairable.
Old Aug 30, 2017 | 10:13 AM
DaddyKnuck's Avatar
DaddyKnuck
Interestingly enough, I checked this AM and no error codes. Just a constant ABS light. I do my own work with the exception of busting rubber. I'll pull the wheel, but got rid of my tire machine this last year.
I've ordered a new one from Surdyke. When the new one is in hand, I plan to do an autopsy on the existing one and see if I can repair it. If I can I'll post pictures.
baldguy13
2014-2024 Touring Models
May 13, 2014 09:38 AM
squaredaway
Aug 31, 2013 08:51 AM
1fathog
Mar 22, 2013 07:21 AM
woodmaniac
Aug 5, 2012 10:44 AM
glide2005
Jan 17, 2011 11:56 AM
