Heel toe shifter
Old Sep 5, 2017 | 08:22 AM
Just Me's Avatar
Just Me
Just remove the heel shifter peg and leave the rest, that's what I did. It also keeps your boot off the engine and scratching up the chrome.
Old Sep 5, 2017 | 08:32 AM
larsfum's Avatar
larsfum
Originally Posted by grbrown
I think that's called lateral thinking!
It's called redundancy Graham. An engineer should know that.
Old Sep 5, 2017 | 09:27 AM
Farmboy666's Avatar
Farmboy666
I removed rear shifter and used the Kuryakyn spacer. Beefed up the linkage while I was at it.
Old Sep 5, 2017 | 10:37 AM
OldPhat's Avatar
OldPhat
One think I did was I found an old socket that is a 1/2 inch long, and got
a longer Allen bolt to move the toe pad out farther from the shifter arm
John
Old Sep 5, 2017 | 11:17 AM
Spartanden's Avatar
Spartanden
wish I could learn to post pictures. I went to Lowes/Menards/Home Depot to their hardware section and go some small white plastic spacers for a couple bucks. I forget the size, maybe 1/2" id, and 1/2" long.... measured the shift lever for the width. took heel shifter off, moved toe shifter outboard and had the spacer behind that.... nice easy and cheap. plus if you looked at it, you would never know what had happened.
Far better than some of the set ups I've seen here!!!
Old Sep 5, 2017 | 12:28 PM
Frostbite's Avatar
Frostbite
Originally Posted by e11charlie
**** been looking at this for two days. Just answered my own question. Took the shifter peg off and just put one behind the other.
Mount that inside piece straight up, put a **** on it and use it as a hand shifter...
Old Sep 5, 2017 | 02:23 PM
Ben221's Avatar
Ben221
Umm. One minor flaw with this plan. Lol. Use your toes to pull the clutch?
Old Sep 5, 2017 | 03:38 PM
Frostbite's Avatar
Frostbite
Ever break a clutch cable and had to get home?
Old Sep 5, 2017 | 03:57 PM
dakotared's Avatar
dakotared
Would this not work?
https://www.harley-davidson.com/stor...er-shaft-cover
Old Sep 5, 2017 | 03:58 PM
ev780's Avatar
ev780
I just left mine on the inside and bought the little cap from Harley.
