Heel toe shifter
Old Sep 6, 2017 | 04:13 PM
  #31
skratch's Avatar
skratch
Originally Posted by dakotared
yeah, it would work fine. but it does not give you the benefit of moving the toe shifter to the outside, heel shifter position.
a long time ago, someone on here had machined spacers that would allow the removal of the heel shifter and moving the toe shifter outboard. I've used it on 3 bikes now. if I ever sell this one, that's one of the things that I will take off and keep.
sure, this piece is definitely 'over engineered' and the same result can be done simpler, but I really like the fact that it does not look like I macgyvered anything.
Old Sep 6, 2017 | 04:23 PM
  #32
Mr-Mike's Avatar
Mr-Mike
Exactly. And that is a benefit, not a disadvantage. Why would you want sticking out further than necessary? The toe shifter is perfect in it's stock position. IMO of course..
Old Sep 6, 2017 | 08:42 PM
  #33
skratch's Avatar
skratch
and I 100% disagree with you. with the toe shifter in it's stock location, I feel like i'm 'pigeon toed' trying to get my toes over to reach the shifter. moving it out 3/4'' makes it more accessible.
and, that is my opinion.
good thing there is more than one way to 'skin a cat' so to speak....
Old Sep 7, 2017 | 05:27 AM
  #34
Slingshot383's Avatar
Slingshot383
My ankle doesn't allow my foot to even contact the stop peg on the stock toe shifter in its stock location. I have a l o n g peg on the toe shifter with it spaced out to the outer location just so I can ride the bike.I have no issues with this set-up, and no problems finding neutral.
Old Sep 7, 2017 | 09:18 AM
  #35
bradn's Avatar
bradn
I know this has nothing to do with the OP's question, but after moving from a single-shifter Dyna to an RGU, I hated the heal shifter. 3000 miles later, I have found that I really like it. Just takes some getting used to.
Old Sep 7, 2017 | 09:31 AM
  #36
hattitude's Avatar
hattitude
Just as a big FWIW... McMaster Carr is your friend...!
I have found they have almost anything I need for custom applications and shade-tree fabrications.....
In this case,
https://www.mcmaster.com/#unthreaded-spacers/=19a3mq3
Old Sep 7, 2017 | 10:20 AM
  #37
grbrown's Avatar
grbrown
Talking
I like my heel shifter - it stops my foot from sliding backwards! Otherwise I don't use it. We must be running out of the different ways we use or lose it by now.....
Old Sep 7, 2017 | 10:24 AM
  #38
cficole's Avatar
cficole
Hah! That's the reason I don't like mine, and why I removed it.
Old Sep 7, 2017 | 12:17 PM
  #39
e11charlie's Avatar
e11charlie
Yeah that's why I removed it also. I like to move my feet around as much as possible. The heel shifter keeps me from being able to put just my toes on the floor boards.
Old Sep 7, 2017 | 12:36 PM
  #40
TexasMotorcycleRider's Avatar
Originally Posted by WoodButcher66
This is what I did about 30,000 miles ago. Added an extended shift lever and never looked back.
